MP3 playback speeds up songs in jukebox mode using DSub
Postby moorek » Mon May 25, 2015 2:38 pm
Problem Description: When using DSub on an Android phone in jukebox mode, songs play normally but after about an hour, every song speeds up similar to a 45 played at 78 speed. The only way to stop it is to completely stop the playlist and restart playback. Worst case is that I have to restart the Subsonic service. In jukebox mode, it will happen again after a while.
Troubleshooting Steps: It does not happen when I play directly using the web interface or when I stream to my phone using DSub. It only seems to be in jukebox mode.
Playback Application and version: DSub 4.9.7 on an HTC One M8 Lollipop
Subsonic Version: 5.2.1 (build 4428) – March 4, 2015
Server Version: jetty-6.1.x, java 1.8.0_31, Windows 8 (65.5 MB / 145.0 MB)
Hardware Platform: Windows 8.1
Java Memory Limit: 150MB
Problem Filename: No specific file.
Output from ffmpeg -i:
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Users\kevin>ffmpeg -i song.mp3 outsong.mp3
ffmpeg version N-69723-gc7ad1f5 Copyright (c) 2000-2015 the FFmpeg developers
  built with gcc 4.9.2 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --
enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-lib
modplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrw
b --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinge
r --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --en
able-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
--enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-
libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enab
le-zlib
  libavutil      54. 18.100 / 54. 18.100
  libavcodec     56. 21.102 / 56. 21.102
  libavformat    56. 19.101 / 56. 19.101
  libavdevice    56.  4.100 / 56.  4.100
  libavfilter     5. 10.100 /  5. 10.100
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
[mp3 @ 0000000004399580] Estimating duration from bitrate, this may be inaccurat
e
Input #0, mp3, from 'song.mp3':
  Metadata:
    title           : Back to Paradise
    track           : 1
    TLEN            : 222328
    publisher       : A&M Records
    genre           : Classic Rock
    album           : Flashback: The Best of .38 Special
    album_artist    : .38 Special
    composer        : Bryan Adams/Jim Vallance/Neil Giraldo
    date            : 1987
  Duration: 00:03:42.34, start: 0.000000, bitrate: 128 kb/s
    Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 128 kb/s
    Stream #0:1: Video: mjpeg, yuvj420p(pc, bt470bg/unknown/unknown), 200x195 [S
AR 300:300 DAR 40:39], 90k tbr, 90k tbn, 90k tbc
    Metadata:
      title           :
      comment         : Other
[swscaler @ 00000000043d7d40] deprecated pixel format used, make sure you did se
t range correctly
[mp3 @ 00000000043c54e0] Frame rate very high for a muxer not efficiently suppor
ting it.
Please consider specifying a lower framerate, a different muxer or -vsync 2
Output #0, mp3, to 'outsong.mp3':
  Metadata:
    TIT2            : Back to Paradise
    TRCK            : 1
    TLEN            : 222328
    TPUB            : A&M Records
    TCON            : Classic Rock
    TALB            : Flashback: The Best of .38 Special
    TPE2            : .38 Special
    TCOM            : Bryan Adams/Jim Vallance/Neil Giraldo
    TPE1            : .38 Special
    TDRC            : 1987
    TSSE            : Lavf56.19.101
    Stream #0:0: Video: png, rgb24, 200x195 [SAR 1:1 DAR 40:39], q=2-31, 200 kb/
s, 90k fps, 90k tbn, 90k tbc
    Metadata:
      title           :
      comment         : Other
      encoder         : Lavc56.21.102 png
    Stream #0:1: Audio: mp3 (libmp3lame), 44100 Hz, stereo, s16p
    Metadata:
      encoder         : Lavc56.21.102 libmp3lame
Stream mapping:
  Stream #0:1 -> #0:0 (mjpeg (native) -> png (native))
  Stream #0:0 -> #0:1 (mp3 (native) -> mp3 (libmp3lame))
Press [q] to stop, [?] for help
frame=    1 fps=0.0 q=0.0 size=       0kB time=00:00:20.74 bitrate=   0.1kbits/s
frame=    1 fps=1.0 q=0.0 size=       0kB time=00:00:41.61 bitrate=   0.1kbits/s
frame=    1 fps=0.7 q=0.0 size=       0kB time=00:01:02.90 bitrate=   0.0kbits/s
frame=    1 fps=0.5 q=0.0 size=       0kB time=00:01:24.37 bitrate=   0.0kbits/s
frame=    1 fps=0.4 q=0.0 size=       0kB time=00:01:45.09 bitrate=   0.0kbits/s
frame=    1 fps=0.3 q=0.0 size=       0kB time=00:02:05.75 bitrate=   0.0kbits/s
frame=    1 fps=0.3 q=0.0 size=       0kB time=00:02:25.86 bitrate=   0.0kbits/s
frame=    1 fps=0.2 q=0.0 size=       0kB time=00:02:47.75 bitrate=   0.0kbits/s
frame=    1 fps=0.2 q=0.0 size=       0kB time=00:03:09.54 bitrate=   0.0kbits/s
frame=    1 fps=0.2 q=0.0 size=       0kB time=00:03:30.15 bitrate=   0.0kbits/s
frame=    1 fps=0.2 q=0.0 Lsize=    3534kB time=00:03:42.32 bitrate= 130.2kbits/
s
video:59kB audio:3474kB subtitle:0kB other streams:0kB global headers:0kB muxing
overhead: 0.014895%
Last ten log file lines: I will do this the next time it happens. Unfortunately, the last time it happened (yesterday), it got into a zombie mode where I couldn't control the playback anymore and I had to kill the Subsonic process and restart the server so the log file doesn't reflect the correct timeframe.
Edit: did it again. Here's the log file. Nothing stands out. Soon as it got to "Weird Science" it sounded like Oingo Boingo turned into the Chipmunks.
[2015-05-25 12:53:13,096] INFO TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-ss] [0] [-i] [d:\music\John Waite\Essential 1976-1986\17 Change.mp3] [-map] [0:0] [-v] [0] [-f] [s16be] [-]
[2015-05-25 12:53:13,112] INFO JukeboxService - moorek starting jukebox for "Essential 1976-1986\17 Change.mp3"
[2015-05-25 12:56:29,829] INFO JukeboxService - moorek stopping jukebox for "Essential 1976-1986\17 Change.mp3"
[2015-05-25 12:56:29,829] INFO TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-ss] [0] [-i] [d:\music\AC_DC\Back in Black\07 You Shook Me All Night Long.mp3] [-map] [0:0] [-v] [0] [-f] [s16be] [-]
[2015-05-25 12:56:29,829] INFO JukeboxService - moorek starting jukebox for "Back in Black\07 You Shook Me All Night Long.mp3"
[2015-05-25 13:00:00,084] INFO JukeboxService - moorek stopping jukebox for "Back in Black\07 You Shook Me All Night Long.mp3"
[2015-05-25 13:00:00,084] INFO TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-ss] [0] [-i] [d:\music\The Clash\The Singles\10 Train in Vain (Stand by Me).mp3] [-map] [0:0] [-v] [0] [-f] [s16be] [-]
[2015-05-25 13:00:00,084] INFO JukeboxService - moorek starting jukebox for "The Singles\10 Train in Vain (Stand by Me).mp3"
[2015-05-25 13:03:11,211] INFO JukeboxService - moorek stopping jukebox for "The Singles\10 Train in Vain (Stand by Me).mp3"
[2015-05-25 13:03:11,211] INFO TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-ss] [0] [-i] [d:\music\Oingo Boingo\Dead Man's Party\09 Weird Science.mp3] [-map] [0:0] [-v] [0] [-f] [s16be] [-]
[2015-05-25 13:03:11,211] INFO JukeboxService - moorek starting jukebox for "Dead Man's Party\09 Weird Science.mp3"
Using Tapatalk
moorek
