Certain Android Clients Not Working
Postby agentred » Sun May 31, 2015 3:53 pm
I've been using Subsonic for years but always had the same issue - it works with some clients and not others. For example, streaming via a web browser is fine, and using the Ultrasonic app on my phone is fine. But when I try to use the Subsonic or Madsonic apps on my phone, I get interminable 'reading from server' delays and timeouts.
This wasn't a problem before because the Ultrasonic app was always fine. Now it's been taken off the app store and the old apk's aren't being updated, leading to frequent crashes. So I'd like to use an alternative, but they just won't connect.
Is there a reason why Ultrasonic can connect, but other apps (Subsonic, Madsonic) won't? It's weird that it streams to everything else. I've pasted the log files below and it seems to recognize Madsonic (player 28) but no dice on actually playing music.
Is this a known issue? Happy to provide further details as necessary, many thanks for the help,
Best,
AR
[5/31/15 11:36:08 AM GMT]   WARN   RESTFilter   Error in REST API: EofException
[5/31/15 1:02:40 PM GMT]   INFO   PlayQueueInputStream   admin listening to "2013 - The Weight That You Buried/01 - Everything Must Go.mp3"
[5/31/15 1:02:49 PM GMT]   INFO   PlayQueueInputStream   admin listening to "2013 - The Weight That You Buried/02 - Your Back Porch.mp3"
[5/31/15 1:02:57 PM GMT]   INFO   PlayQueueInputStream   admin listening to "2013 - The Weight That You Buried/03 - Stateside.mp3"
[5/31/15 1:03:06 PM GMT]   INFO   PlayQueueInputStream   admin listening to "2013 - The Weight That You Buried/04 - No Good.mp3"
[5/31/15 1:03:13 PM GMT]   INFO   PlayQueueInputStream   admin listening to "2013 - The Weight That You Buried/05 - Your Back Porch (Acoustic).mp3"
[5/31/15 1:03:19 PM GMT]   INFO   PlayQueueInputStream   admin listening to "2013 - The Weight That You Buried/06 - No Good (Acoustic).mp3"
[5/31/15 4:07:38 PM GMT]   INFO   PlayerDao   Created player 28.
agentred
Users browsing this forum: Google [Bot] and 39 guests
