Subsonic on server
Subsonic on server
Postby wcwman18 » Tue Jun 02, 2015 4:07 pm
I have installed subsonic on a server that I want to stream from.
How can I run the GUI without my SSH session having to stay open?
I close the SSH session and get the following error. Service Temporarily Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache/2.2.22 (Debian)
Once I get that part working correct what server info would I put in my roku player to connect? Everything I have tried so far has failed.
If it helps I have it installed on a Feral Hosting Slot and I used this guide to install. https://www.feralhosting.com/faq/view?question=159
wcwman18
Re: Subsonic on server
Postby wcwman18 » Wed Jun 03, 2015 5:32 am
Anybody?
wcwman18
Postby mrfloppy » Wed Jun 03, 2015 6:05 am
How did you start SubSonic?
The roku-player needs your server ip address and port plus your user credentials.
mrfloppy
Postby wcwman18 » Wed Jun 03, 2015 6:13 am
I assume after I install from these instructions that it would stat automatically. https://www.feralhosting.com/faq/view?question=159
wcwman18
Postby mrfloppy » Wed Jun 03, 2015 8:06 am
Well, i don't know that install script but you get an answer from your apache webserver.
How did you try to reach your SubSonic gui? It should be http://IP_ADDRRESS:PORT default port is 4040
mrfloppy
Postby manwithaplan » Wed Jun 03, 2015 5:25 pm
Also, what version of Subsonic are you attempting to get working with the Roku?
manwithaplan
