Problems streaming music to Denon receiver from subsonic DLN
Postby dbutler31415 » Fri Jun 05, 2015 4:39 pm
Problem Description: I cant stream music to my Denon AVR-S900W receiver via DLNA. I get a Server Error Popup on the Denon display. No evidence
in subsonic log file.
Troubleshooting Steps: I just looked at subsonic.log
Playback Application and version: Denon AVR-S900W receiver
Subsonic Version: 5.2.1 (build 4428) – March 4, 2015
Server Version: jetty-6.1.x, java 1.7.0_79, Linux (78.3 MB / 135.0 MB)
Hardware Platform: Linux Ubuntu 14.10
Java Memory Limit: 150m
Problem Filename: 01 Don't Want You No More.mp3'
Output from ffmpeg -i:
dbutler@content:/data1/music/The Allman Brothers Band/Beginnings$ /var/subsonic/transcode/ffmpeg -i 01\ Don\'t\ Want\ You\ No\ More.mp3
ffmpeg version N-61445-gdded5ed Copyright (c) 2000-2014 the FFmpeg developers
  built on Mar 14 2014 05:12:40 with gcc 4.6 (Debian 4.6.3-1)
  configuration: --prefix=/root/ffmpeg-static/32bit --arch=x86_32 --extra-cflags='-m32 -I/root/ffmpeg-static/32bit/include -static' --extra-ldflags='-m32 -L/root/ffmpeg-static/32bit/lib -static' --extra-libs='-lxml2 -lexpat -lfreetype' --enable-static --disable-shared --disable-ffserver --disable-doc --enable-bzlib --enable-zlib --enable-postproc --enable-runtime-cpudetect --enable-libx264 --enable-gpl --enable-libtheora --enable-libvorbis --enable-libmp3lame --enable-gray --enable-libass --enable-libfreetype --enable-libopenjpeg --enable-libspeex --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-version3 --enable-libvpx
  libavutil      52. 66.101 / 52. 66.101
  libavcodec     55. 52.102 / 55. 52.102
  libavformat    55. 34.101 / 55. 34.101
  libavdevice    55. 11.100 / 55. 11.100
  libavfilter     4.  3.100 /  4.  3.100
  libswscale      2.  5.101 /  2.  5.101
  libswresample   0. 18.100 /  0. 18.100
  libpostproc    52.  3.100 / 52.  3.100
[mp3 @ 0xa9c3440] Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from '01 Don't Want You No More.mp3':
  Metadata:
    TLEN            : 145867
    title           : Don't Want You No More
    track           : 1
    artist          : The Allman Brothers Band
    genre           : Rock/Pop
    album           : Beginnings
  Duration: 00:02:26.39, start: 0.000000, bitrate: 127 kb/s
    Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 128 kb/s
    Stream #0:1: Video: mjpeg, yuvj420p(pc), 200x198 [SAR 300:300 DAR 100:99], 90k tbr, 90k tbn, 90k tbc
    Metadata:
      title           :
      comment         : Other
Last ten log file lines:
6/5/15 12:09:06 PM EDT]    INFO   FolderBasedContentDirectory   UPnP request - objectId: folder-18, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI@dlna:profileID,upnp:searchClass, firstResult: 0, maxResults: 50
[6/5/15 12:09:06 PM EDT]    INFO   FolderBasedContentDirectory   UPnP request - objectId: folder-0, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI@dlna:profileID,upnp:searchClass, firstResult: 0, maxResults: 50
[6/5/15 12:09:07 PM EDT]    INFO   FolderBasedContentDirectory   UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI@dlna:profileID,upnp:searchClass, firstResult: 0, maxResults: 50
[6/5/15 12:09:12 PM EDT]    INFO   FolderBasedContentDirectory   UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI@dlna:profileID,upnp:searchClass, firstResult: 0, maxResults: 50
[6/5/15 12:09:14 PM EDT]    INFO   FolderBasedContentDirectory   UPnP request - objectId: playlists, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI@dlna:profileID,upnp:searchClass, firstResult: 0, maxResults: 50
[6/5/15 12:09:15 PM EDT]    INFO   FolderBasedContentDirectory   UPnP request - objectId: playlist-5, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI@dlna:profileID,upnp:searchClass, firstResult: 0, maxResults: 50
[6/5/15 12:13:14 PM EDT]    INFO   FolderBasedContentDirectory   UPnP request - objectId: playlists, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI@dlna:profileID,upnp:searchClass, firstResult: 0, maxResults: 50
[6/5/15 12:13:15 PM EDT]    INFO   FolderBasedContentDirectory   UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI@dlna:profileID,upnp:searchClass, firstResult: 0, maxResults: 50
[6/5/15 12:13:17 PM EDT]    INFO   FolderBasedContentDirectory   UPnP request - objectId: folder-0, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI@dlna:profileID,upnp:searchClass, firstResult: 0, maxResults: 50
[6/5/15 12:13:19 PM EDT]    INFO   FolderBasedContentDirectory   UPnP request - objectId: folder-123, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI@dlna:profileID,upnp:searchClass, firstResult: 0, maxResults: 50
[6/5/15 12:13:21 PM EDT]    INFO   FolderBasedContentDirectory   UPnP request - objectId: folder-4383, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI@dlna:profileID,upnp:searchClass, firstResult: 0, maxResults: 50
dbutler31415
Re: Problems streaming music to Denon receiver from subsonic
Postby dbutler31415 » Fri Jun 12, 2015 1:34 pm
just a followup to this item since there were no other replies.
I really wanted to give subsonic a chance and I do like the product and the GUI. But I was not able
to collect any information on the DLNA/UPNP handshakes to help figure out what was wrong. Log files on the server did not give any info
and upnp-inspector did collect some information but not enough to identify one particular issue.
As as aside, I tried various DLNA servers besides Subsonic, minidlna, XBMC/Kodi, but the one that finally worked for me out of the box was MediaBrowser/Emby.
Others trying to stream to Denon might want to give it a look.
Symptoms of the issues I was seeing for the record
Subsonic: could see the music folders and the files, but when attempting to play, would display a server error on the Denon
Minidlna: could not see the music folders
Kodi: could not see the music folders
so I am using Emby as a media server on a linux box, and a Denon remote app on iphone/ipad to drive the music to my outdoor speakers as I sit by the pool.
I will stop back periodically and retry Subsonic.
dbutler31415
Postby alphawave7 » Sat Jun 13, 2015 3:02 am
I'm curious if you could accomplish this using BubbleUPnP as a control point, and Subsonic as server?
Postby benzilla » Fri Jul 03, 2015 3:22 am
I'm having this exact problem with my Denon network player as well. I had been using Subsonic as a DNLA server to stream to it for a while and it worked great. It's now suddenly giving me the "server error" message as described in the other messages on this thread. I'm on 5.2.1 and I'm guessing the trouble started with the previous upgrade. Here're the particulars:
Problem Description: Denon network streamer stereo component can connect to Subsonic DNLA server, reads folders, reads albums, can drill into albums to get to songs... but when trying to play songs, the receiver throws a "server error" message.
Troubleshooting Steps: Upgraded Subsonic to most recent version. Verified that Subsonic is working fine playing/connecting via PC, phone, etc.
Playback Application and version: Denon DNP 720 network streamer
Server Version: jetty-6.1.x, java 1.7.0_67, Windows 8 (63.6 MB / 109.3 MB)
Hardware Platform: Win 8
Problem Filename: All music files
[7/2/15 9:22:24 PM EDT]   INFO   DaoHelper   Checking database schema.
[7/2/15 9:22:25 PM EDT]   INFO   DaoHelper   Done checking database schema.
[7/2/15 9:22:25 PM EDT]   INFO   VersionService   Resolved local Subsonic version to: 5.2.1
[7/2/15 9:22:25 PM EDT]   INFO   PlayerDao   Deleted 1 player(s) that haven't been used after Sun May 03 21:22:25 EDT 2015
[7/2/15 9:22:25 PM EDT]   INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Fri Jul 03 03:00:00 EDT 2015
[7/2/15 9:22:25 PM EDT]   INFO   UPnPService   Starting UPnP service...
[7/2/15 9:22:25 PM EDT]   INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Thu Jul 02 21:27:25 EDT 2015
[7/2/15 9:22:25 PM EDT]   INFO   UPnPService   Enabling UPnP/DLNA media server
[7/2/15 9:22:25 PM EDT]   INFO   UPnPService   Starting UPnP service - Done!
[7/2/15 9:24:43 PM EDT]   INFO   NetworkService   Successfully forwarding port 8080.
[7/2/15 9:27:25 PM EDT]   INFO   PodcastService   Starting scheduled Podcast refresh.
[7/2/15 9:27:25 PM EDT]   INFO   PodcastService   Completed scheduled Podcast refresh.
[7/2/15 9:53:24 PM EDT]   INFO   PlayQueueInputStream   admin listening to "(2015) MOJO Proudly Presents Physical Graffiti Redrawn\01 - White Denim - Custard Pie.mp3"
[7/2/15 9:53:38 PM EDT]   INFO   PlayQueueInputStream   admin listening to "(2015) MOJO Proudly Presents Physical Graffiti Redrawn\02 - Blackberry Smoke - The Rover.mp3"
[7/2/15 9:53:59 PM EDT]   INFO   PlayQueueInputStream   admin listening to "(2015) MOJO Proudly Presents Physical Graffiti Redrawn\03 - Miraculous Mule - In My Time Of Dying.mp3"
[7/2/15 9:54:14 PM EDT]   INFO   PlayQueueInputStream   admin listening to "(2015) MOJO Proudly Presents Physical Graffiti Redrawn\04 - The Temperance Movement - Houses Of The Holy.mp3"
[7/2/15 9:59:58 PM EDT]   INFO   FolderBasedContentDirectory   UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI,upnp:searchClass, firstResult: 0, maxResults: 50
[7/2/15 10:00:00 PM EDT]   INFO   FolderBasedContentDirectory   UPnP request - objectId: folder-31277, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI,upnp:searchClass, firstResult: 0, maxResults: 50
[7/2/15 10:00:01 PM EDT]   INFO   FolderBasedContentDirectory   UPnP request - objectId: folder-31279, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI,upnp:searchClass, firstResult: 0, maxResults: 50
[7/2/15 10:00:02 PM EDT]   INFO   FolderBasedContentDirectory   UPnP request - objectId: folder-32029, browseFlag: BrowseDirectChildren, filter: @childCount,dc:creator,upnp:album,upnp:artist,res,res@protection,res@duration,res@size,upnp:albumArtURI,upnp:searchClass, firstResult: 0, maxResults: 50
[7/2/15 10:26:51 PM EDT]   INFO   NetworkService   Successfully forwarding port 8080.
[7/2/15 11:17:17 PM EDT]   INFO   PlayerDao   Created player 6.
[7/2/15 11:17:18 PM EDT]   INFO   VersionService   Resolved latest Subsonic final version to: 5.2.1
[7/2/15 11:17:18 PM EDT]   INFO   VersionService   Resolved latest Subsonic beta version to: 5.2.beta1
Any help would be appreciated!
benzilla
Postby benzilla » Sat Jul 04, 2015 5:56 pm
Just to follow up, there seem to be a few other unsolved threads with people reporting this behavior--DNLA devices being able to connect to Subsonic, drill into the directory structure, but then throw an error when trying to actually play tracks:
viewtopic.php?f=2&t=15723&p=67899&hilit=dnla+server+error#p67899
viewtopic.php?f=2&t=14663&p=66745&hilit=denon#p64618
viewtopic.php?f=2&t=15377&p=66724&hilit=denon#p66724
Anyone have any thoughts on how to troubleshoot this?
benzilla
Postby SPo » Fri Sep 11, 2015 5:34 pm
have look in my posting. Maybe your server has more than one ethernet interface as well.
Check the Metadata info of your media file and have a closer look at the ip
viewtopic.php?f=2&t=15944
SPo
Users browsing this forum: No registered users and 67 guests
