Trouble Establishing Connection
Postby zavosh » Fri Jun 05, 2015 6:10 pm
Problem: I can't get iSub to establish a connection outside of wifi. My first Mac Pro could connect without issue, but the new Mac Pro can connect but only via wifi. Once I switch my phone over to LTE it loses connection. I went through the standard troubleshooting steps but can't solve it. I've also tried mimicking everything on my old Mac Pro to conform to the new Mac Pro, both running 10.9.5. Running version 5.2.1
App: iSub
Subsonic: Premium
Subsonic Version: 5.2.1
Server Version: jetty-6.1.x, java 1.8.0_25, Mac OS X (72.1 MB / 131.5 MB)
Status: Successfully forwarding port 4040.
Log:
[6/5/15 4:38:07 AM PDT] INFO NetworkService Successfully forwarding port 4040.
[6/5/15 5:40:14 AM PDT] INFO NetworkService Successfully forwarding port 4040.
[6/5/15 6:42:22 AM PDT] INFO NetworkService Successfully forwarding port 4040.
[6/5/15 7:44:30 AM PDT] INFO NetworkService Successfully forwarding port 4040.
[6/5/15 8:46:37 AM PDT] INFO NetworkService Successfully forwarding port 4040.
[6/5/15 9:48:45 AM PDT] INFO NetworkService Successfully forwarding port 4040.
[6/5/15 10:00:44 AM PDT] INFO PlayQueueInputStream zavosh listening to "BBC Radio1 Breezeblock/Breezeblock Mix 16-03-2004.mp3"
[6/5/15 10:02:03 AM PDT] WARN RESTFilter Error in REST API: EofException
[6/5/15 10:02:03 AM PDT] ERROR JAXBWriter Failed to marshal JAXB
[6/5/15 10:02:03 AM PDT] ERROR RESTFilter Failed to write error response.
[6/5/15 10:50:54 AM PDT] INFO NetworkService Successfully forwarding port 4040.
Looks like the last 4 lines tell what the issue might be?
TIA
zavosh
Re: Trouble Establishing Connection
Postby zavosh » Mon Jun 08, 2015 8:02 pm
Anyone? The error messages in the log are clearly visible, but I can't decipher what they mean or how to solve the issue. Someone with experience this care to help?
zavosh
Postby alphawave7 » Tue Jun 09, 2015 2:46 am
This would appear to be a firewall or router port problem. Use canyousee,org to test your port.
Postby zavosh » Tue Jun 09, 2015 7:31 am
You're right. It was. I had to go through the port forwarding process again. I guess I never had to do this with my previous setup. Thanks!
zavosh
