Playlists Stop After A Few Songs
Postby fader_rider » Mon Jun 08, 2015 9:54 pm
Problem Description: Updated to latest version and migrated the service to a new machine. Copied Subsonic folder contents into installation directory (the default one). Everything comes up on other machines and mobile devices. However today at work, through Chrome, custom playlists will only playback 5 or so songs if I shuffle the play list. If I let it play straight through, the most songs I have been able to play back are 16.
Troubleshooting Steps: Reloading screen, loading a different playlist, coming back to 'broken' one..all customs seem to present this behavior. I am trying a regular album playlist as I write this.
Playback Application and version: I am accessing my server through Chrome. SS version is 5.2.1 build 4428
Subsonic Version: 5.2.1 (build 4428) – March 4, 2015
Server Version: jetty-6.1.x, java 1.8.0_31, Windows 7 (74.9 MB / 145.0 MB)
Hardware Platform: Windows 7 Ultimate x64, up to date in terms of win update.
Java Memory Limit: I am assuming this is the Memory limit (MB) value in the SS control panel: 150 mb
Problem Filename: N/A. This appears to be specific to playlists.
Output from ffmpeg -i: N/A, issue does not appear to be file specific. Also, these playlists had all played successfully prior to the move/upgrade
Last ten log file lines: [6/9/15 2:37:27 PM PDT] INFO InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Unrecognized option 'b:a'
[6/9/15 2:37:27 PM PDT] INFO InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) c:\subsonic\transcode\ffmpeg: failed to set value '192k' for option 'b:a'
[6/9/15 2:40:52 PM PDT] INFO PlayQueueInputStream Ian listening to "Low - The Great Destroyer (2005) - Indie\01. Low - Monkey.mp3"
[6/9/15 2:40:52 PM PDT] INFO TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-f] [mp3] [-i] [T:\Music Library\Low - The Great Destroyer\Low - The Great Destroyer (2005) - Indie\01. Low - Monkey - [-ab] [192k] [-v] [0] [-f] [mp3] [-]
[6/9/15 2:41:38 PM PDT] INFO InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) ffmpeg version N-31653-gfaa3381, Copyright (c) 2000-2011 the FFmpeg developers
[6/9/15 2:41:38 PM PDT] INFO InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) built on Jul 28 2011 01:57:12 with gcc 4.6.1
[6/9/15 2:41:38 PM PDT] INFO InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) configuration: --enable-gpl --enable-version3 --enable-memalign-hack --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
[6/9/15 2:41:38 PM PDT] INFO InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavutil 51. 11. 0 / 51. 11. 0
[6/9/15 2:41:38 PM PDT] INFO InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavcodec 53. 9. 0 / 53. 9. 0
[6/9/15 2:41:38 PM PDT] INFO InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavformat 53. 6. 0 / 53. 6. 0
[6/9/15 2:41:38 PM PDT] INFO InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) libavdevice 53. 2. 0 / 53. 2. 0
Questions if you feel they are relevant:
1. Is my last backup of the subsonic folder compatible with the new version? I think i was just on the last major release
2. I am a subscriber. Did that perhaps expire? thought it was a one time thing but perhaps it isn't
3. Is there a setting somewhere specific to the new distribution that limits playback? I have missed settings before and would hate to waste anyone's time with all the above if it is just my own lack of knowledge
Love Subsonic, have for years. thank you in advance for any help you can provide. Glad to re-up if that's what it takes.
fader_rider
Re: Playlists Stop After A Few Songs
Postby alphawave7 » Tue Jun 09, 2015 3:23 am
First, check your license 'About' should show 'Subsonic Premium', which can be clicked to show license status.
Try removing the transcoding from playback in Settings-Player on the specific Chrome player being used.
Postby fader_rider » Tue Jun 09, 2015 6:36 am
Thank you Alpha. I reinstalled 4.9 and everything seems to be in working order again. When i get some time I will reinstall to the current version and if it doesn't work again I'll try this.
fader_rider
