Forbid Indexing of Certain Folders?
Postby quix » Tue Feb 10, 2009 6:27 pm
Is there a way to remove certain folders from indexing? If not, i would like to see this feature. I've seen other systems that you simply put a file like .noindex in the folder.
It's weird to listen to random Heavy Metal songs and then to Itsy Bitsy Spider from the Children's folder ;-)
One quick note, I _LOVE_ 3.6! Great upgrade from 3.5.
TIA
quix
Postby sindre_mehus » Tue Feb 10, 2009 9:41 pm
You know you can select music folder when creating a random playlist? That should solve your problem?
Postby quix » Wed Feb 11, 2009 9:17 pm
Thanks for the quick reply.
The random feature is fantastic, and will do the trick. Thanks!
quix
Users browsing this forum: No registered users and 35 guests
