Solved: Upgrading Subsonic
Postby MRPockets » Fri Jun 12, 2015 2:33 am
After much searching I have been unable to find an answer to this question. I am needing to upgrade to the latest Subsonic release but don't want to take the time again to set everything up from scratch. Is there a way to upgrade without loosing current users & settings?
Info: I'm running Subsonic 5.0 (build 4100) on Ubuntu Server 14.04.
MRPockets
Re: Upgrading Subsonic
Postby MRPockets » Mon Jun 15, 2015 3:00 pm
Update: apparently you can simply run the updated install right over an existing installation and it will effectively update the old one rather than making a clean install.
MRPockets
