java.sql.SQLException: Out of Memory
Postby zbmott » Sat Jun 13, 2015 1:09 am
Problem description: When I go to my Subsonic URL, I get an error 503: SERVICE_UNAVAILABLE
Troubleshooting steps: I've tried adjusting the --max-memory flag in /etc/default/subsonic up to 1024 so far.
Playback application and version: The web player. Subsonic v5.2.1.
Server version: 5.2.1
Hardware platform:
> uname -a
Linux 3.2.0-57-generic #87-Ubuntu SMP Tue Nov 12 21:35:10 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
> lsb_release
LSB Version:    core-2.0-amd64:core-2.0-noarch:core-3.0-amd64:core-3.0-noarch:core-3.1-amd64:core-3.1-noarch:core-3.2-amd64:core-3.2-noarch:core-4.0-amd64:core-4.0-noarch
Distributor ID: Ubuntu
Description:    Ubuntu 12.04.5 LTS
Release:        12.04
Codename:       precise
Java Memory Limit: 1024
Last 10 log file lines:
[2015-06-12 20:50:35,624] INFO DaoHelper - Checking database schema.
[2015-06-12 20:51:06,708] ERROR DaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: Out of Memory
        at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
        at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:429)
        at net.sourceforge.subsonic.dao.schema.Schema25.execute(Schema25.java:38)
        at net.sourceforge.subsonic.dao.DaoHelper.checkDatabase(DaoHelper.java:122)
        at net.sourceforge.subsonic.dao.DaoHelper.<init>(DaoHelper.java:75)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:534)
... the stack trace goes on for some time
Caused by: java.sql.SQLException: Out of Memory
        at java.sql.DriverManager.getConnection(DriverManager.java:615)
        at java.sql.DriverManager.getConnection(DriverManager.java:167)
        ... 76 more
[2015-06-12 20:51:06,875] INFO VersionService - Resolved local Subsonic version to: 5.2.1
I figure you're probably also interested in my Java version:
> java -version
java version "1.6.0_34"
OpenJDK Runtime Environment (IcedTea6 1.13.6) (6b34-1.13.6-1ubuntu0.12.04.1)
OpenJDK 64-Bit Server VM (build 23.25-b01, mixed mode)
I really don't know what's changed. I don't log into my server very often, but it was fine the last time I tried to use it. I haven't run any system updates since then, nor have I updated the subsonic server. Any help at all will be appreciated.
EDIT
Okay, so I've been able to stop generating 503s by increasing the memory limit to 4096 -- which all of my machine's physical memory. Why does Subsonic all of a sudden need so much memory? When I started troubleshooting this problem tonight, the --max-memory flag was set to 150. I'm going to try cleaning up the database; maybe that will help.
EDIT 2
Maybe I should just keep trying things before I start posting to the forums? Sorry about the edits. I tried to perform a database cleanup, but got the following enormous stack trace:
org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select max(id) from media_file where not present]; S1000 General error java.util.NoSuchElementException in statement [select max(id) from media_file where not present]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select max(id) from media_file where not present]
   at org.springframework.jdbc.core.JdbcTemplate.queryForList(JdbcTemplate.java:768)
   at net.sourceforge.subsonic.dao.AbstractDao.queryForInt(AbstractDao.java:132)
   at net.sourceforge.subsonic.dao.MediaFileDao.expunge(MediaFileDao.java:537)
   at net.sourceforge.subsonic.controller.MusicFolderSettingsController.expunge(MusicFolderSettingsController.java:74)
   at net.sourceforge.subsonic.controller.MusicFolderSettingsController.formBackingObject(MusicFolderSettingsController.java:57)
   at org.springframework.web.servlet.mvc.AbstractFormController.getErrorsForNewForm(AbstractFormController.java:358)
   at org.springframework.web.servlet.mvc.AbstractFormController.showNewForm(AbstractFormController.java:338)
   at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:278)
Caused by: java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select max(id) from media_file where not present]
   ... 65 more
I also learned that Subsonic is currently using 2512M of memory. Excessive!
zbmott
