Cannot access 'recently added', 5.2.1, Windows
Postby ezraghast » Thu Jun 18, 2015 2:55 pm
Hi. For the past couple of days I've been having problems accessing 'Recently Added' files thru the web interface and via clients. Older files work as expected. I'm hoping someone here can asvise on a course of action before I delete the db and rescan. Error info provided below. Thanks!
Problem Description: 'Recently Added' files are inaccessible.
Troubleshooting Steps: Resarting the subsonic service. Rescanning the database. Cleaning Up the database.
Playback Application and version: Web, Dsub, iSub
Subsonic Version: 5.2.1 (build 4428) – 04 March 2015
Server Version: jetty-6.1.x, java 1.8.0_31, Windows 8 (72.5 MB / 94.4 MB)
Hardware Platform: Windows
Java Memory Limit: 200
Problem Filename: N/A
Output from ffmpeg -i: N/A
Last ten log file lines:
[17/06/15 23:47:29 BST]    INFO   DaoHelper   Checking database schema.
[17/06/15 23:47:33 BST]    INFO   Schema47   Database table 'media_file' not found. Creating it.
[17/06/15 23:47:33 BST]    ERROR   DaoHelper   Failed to initialize database.
[17/06/15 23:47:34 BST]    INFO   VersionService   Resolved local Subsonic version to: 5.2.1
[17/06/15 23:47:36 BST]    INFO   MediaScannerService   Automatic media scanning disabled.
[17/06/15 23:47:36 BST]    INFO   UPnPService   Starting UPnP service...
[17/06/15 23:47:36 BST]    INFO   PodcastService   Automatic Podcast update disabled.
[17/06/15 23:47:37 BST]    INFO   UPnPService   Disabling UPnP/DLNA media server
[17/06/15 23:47:37 BST]    INFO   UPnPService   Starting UPnP service - Done!
[17/06/15 23:47:46 BST]    INFO   NetworkService   Successfully forwarding port 4040.
Error:
Subsonic encountered an internal error..
Exception    org.springframework.dao.TransientDataAccessResourceException
Message    PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
Java version    Oracle Corporation 1.8.0_31
Operating system    Windows 8 6.2
Server    jetty-6.1.x
Memory    Used 81 of 94 MB
Stack trace    org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
   at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:666)
   at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:698)
   at org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate.query(NamedParameterJdbcTemplate.java:133)
   at org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate.query(NamedParameterJdbcTemplate.java:137)
   at net.sourceforge.subsonic.dao.AbstractDao.namedQuery(AbstractDao.java:104)
   at net.sourceforge.subsonic.dao.MediaFileDao.getNewestAlbums(MediaFileDao.java:278)
   at net.sourceforge.subsonic.service.MediaFileService.getNewestAlbums(MediaFileService.java:276)
   at net.sourceforge.subsonic.controller.HomeController.getNewest(HomeController.java:162)
   at net.sourceforge.subsonic.controller.HomeController.handleRequestInternal(HomeController.java:90)
   at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:47)
Caused by: java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
   ... 65 more
ezraghast
Re: Cannot access 'recently added', 5.2.1, Windows
Postby alphawave7 » Thu Jun 18, 2015 4:19 pm
S1000 errors are usually corrupt db...search forum for S1000 error for several solutions, some less destructive than others.
Sent from my Nexus 6 using Tapatalk
Postby ezraghast » Sun Jun 28, 2015 9:17 am
Thanks for pointing that out alphawave7. A closer reading of the error log would have revealed it for myself :oops: I backed up the script file and rescanned the library and we're as good as new. I'm not sure if it's worth pointing out that I've only run into problems like this with recent versions of Subsonic and/or Java. Thanks again.
ezraghast
