FLAC / ALAC not playing.
Postby Thurios » Fri Jun 19, 2015 9:39 am
Hello!
I started having problems playing any flac or alac files. Normal mp3 files are playing fine but flac files won't start playing on the webplayer nor in android app. I'm running subsonic server on Windows server 2012 r2. Issues started after I upgraded my subsonic to 5.2.1 version and did database cleanup with command line. I tried to downgrade Subsonic to 5.2 version but the problem still exists. Any idea what might be causing the problem?
Thurios
Re: FLAC / ALAC not playing.
Postby Thurios » Fri Jun 19, 2015 10:14 am
I did clean install and it's working again. Anyways if anyone knows what caused the problem please share.
Thurios
Postby jru » Tue Jun 23, 2015 9:50 pm
I have a similar issue. None of my FLAC files will play using Firefox. However they play fine using Chrome.
Any ideas how to fix this? I don't want to reinstall my Subsonic server from scratch if I can avoid it.
Jim
jru
