Downloading songs to my smart phone
Postby dhsmith77 » Tue Jun 23, 2015 8:48 pm
The operating features material indicates that it is possible to download music from my server to my mobile device for local play as opposed to streaming. I can't find anyplace to do that on my mobile device... am I missing something? Or is that just a feature that I'm imagining exists that actually doesn't... thanks
dhsmith77
Re: Downloading songs to my smart phone
Postby jedinerd » Wed Jun 24, 2015 8:30 pm
Using the subsonic mobile app you can designate where it stores the files it is streaming. If you set that cache to be very large ( in my case 20 GB ), then set the app to pre-download a large number of songs on play, and then also set it to only download on wifi it is pretty easy to pre-load with music and play from your device sans streaming. Hope that helps.
jedinerd
