brand new install
brand new install
Postby djrat » Sun Oct 01, 2006 11:08 pm
I have a server running FC5
I have followed the install directions on the download page.
I have re-installed twice...
Also, FC5 puts the tomcat folder in
var/lib/tomcat5
thus: var/lib/tomcat5/webapps/subsonic is created when I logon to localhost on port 8080.
A link is created on the system in...
/usr/share/tomcat5 with the same folders and files.
Since the link is setup and the folders are created, I assume tomcat is working. Also if I go to http:// localhost : 8080/subsonic/
I get the message from Tomcat that "the requested resource (/subsonic)
is not available.
If I try any other address combination I get error 404.....
FC5 is up to date, I run PHP and MYSQL on the system with a local server for developement and learning. I am not an EXPERT but I'm not a noob.
Another thing, there is no Subsonic or tomcat error log file. FC5 saves the file to
var/log/tomcat5/catalina.out
which gives me 5 pages of information I have no use for.
By looking at the index.html file, I see that the file is pointing to
Index.view......
Well Firefox locks on that, as does IE.....I cant find the file anywhere...
What am I missing?
I want to set up your software for a site I am designing.
Keep in mind I know Enough about Linux to be dangerous....but I dont mind experimenting with Ideas.
thanx for any replies.
djrat
Postby Inge » Mon Nov 13, 2006 7:54 pm
Don't know if this helps, but I am running Subsonic 2.9 beta on FC6.
First of all, does http:// localhost : 8080/ give you the Tomcat welcome page? If not, start looking at your Tomcat setup.
I am absolutely not an expert on Linux nor Tomcat, but will give you a brief description on my working configuration below.
I have downloaded Tomcat 6 from the Apache DL pages, after FC6 install. I didn't install the package that came with the FC distribution. Tomcat was then installed to the folder of my choice. Remember to set the correct JAVA_HOME before starting Tomcat (It requires 1.5, Java version shipped with FC6 is 1.4.something), I am setting the exporting the variable in startup.sh
catalina.out is on my system placed in <installfolder>/logs, and subsonic.log in /var/subsonic/ - remember to create this folder before running Subsonic for the first time and change owner or group to your Tomcat user, if not running Tomcat as root.
Good luck!
Inge.
Inge
Postby djrat » Tue Nov 14, 2006 3:19 am
I had almost forgotten about Subsonic.
I gave up after no replies for a week or so.
I will give your ideas a try.
Thanx.
djrat
Users browsing this forum: No registered users and 44 guests
