Play Queue Is Not Smooth On Chrome
Postby ebasta » Sun Jul 26, 2015 9:31 am
The pop-up play queue area on the Subsonic interface does not pop-up smoothly anymore on Chrome. I have cleared the cache of the browser and cleared the cache in the java control panel. Both Mac and PC versions of chrome have had this happen. Safari, Firefox, IE all have a smooth pop-up play queue. Is this a server side issue or local?
ebasta
Re: Play Queue Is Not Smooth On Chrome
Postby IwishIcanFLighT » Mon Aug 24, 2015 8:51 am
Got the same issue: this bug is really weird. Working perfectly fine in Firefox but Chrome decided to mess it up for some reasons.
It's with the latest version of Google Chrome. If you downgrade it works again. But since Google doesn't want you to downgrade... :roll:
A friend of mine got the issue too, so it seems like the bug occurs pretty frequently. Hopefully Sindre can try to fix it with the upcoming 5.3 beta builds. :wink:
IwishIcanFLighT
Postby somercamb » Thu Oct 29, 2015 3:46 pm
I have been getting that wonky occurrence as well. just installed 5.3 and it still continues...
somercamb
