SSL connection broken with SONOS 5.4 update
Postby MikeLegit » Mon Aug 03, 2015 7:16 am
My SONOS controllers recently upgraded to v5.4 and now subsonic quit working. :( It's been working flawlessly for 7 months! I tried to remove the SONOS controller and re-add it again with the same settings and it's adds fine, just the login no longer works when I try to add the account in the SONOS interface. Looks like something needs updated in SONOS or Subsonic code to support it?? :cry: I checked the help page and settings have not changed.
Settings I used are (I use SSL so the 4041 port is correct):
https://192.168.1.1:4041/subsonic/ws/Sonos?ip=192.168.1.1
1200
Session ID
5   https://192.168.1.1:4041/subsonic/sonos/strings.xml
1   https://192.168.1.1:4041/subsonic/sonos/presentationMap.xml
Container Type – Music Service
Capabilities – Search, Favorites, Extended Metadata
Putting the URL directly into a browser hits the subsonic server with this response which is correct and valid:
<soap:Envelope>
<soap:Body>
<soap:Fault>
<faultcode>soap:Server</faultcode>
<faultstring>No such operation:  (HTTP GET PATH_INFO: /subsonic/ws/Sonos)</faultstring>
</soap:Fault>
</soap:Body>
</soap:Envelope>
Errors in subsonic log now:
[8/3/15 7:08:19 AM GMT]    WARN   SonosFaultInterceptor   Error: org.apache.cxf.interceptor.Fault: No such operation: (HTTP GET PATH_INFO: /subsonic/ws/Sonos)
Anyone have any fixes? non-SSL works fine on port 4040, but I need SSL remotely. Subsonic seems to be redirecting to 4041 SSL port if both 4040 and 4041 are enabled. :evil:
Regards.
This forum is blocking my ISP with their aggressive filtering, so I can only login via my phone. After all my contributions (and more than 2X the recommend donation), the site admin is unwilling to help. You can find me at SmallNetBuilder Forums.
MikeLegit
Re: Subsonic support broken with SONOS 5.4 update
Postby madhusker » Fri Aug 07, 2015 5:55 am
They broke SSL it seems. Works fine if you disable your SSL port. :roll:
What needs fixed? Subsonic or Sonos?
-MH
madhusker
Re: SSL connection broken with SONOS 5.4 update
Postby sindre_mehus » Wed Aug 12, 2015 6:40 am
It works for me :)
If you use one of the native installers for Subsonic (for Mac, Windows, Linux), the embedded Jetty server allows non-SSL traffic for Sonos. This means that the proper URL to use for the Sonos settings is http://192.168.1.1:4040/subsonic/ws/Son ... 92.168.1.1 in your case.
Postby madhusker » Tue Sep 08, 2015 2:09 am
It looks to be something with QNAP-569L. I installed subsonic on a ubuntu server and it works fine there with Sonos. I guess I'll have to run 2 subsonics for a while until it's sorted out. :/ Worked find for 8 months.
madhusker
Users browsing this forum: No registered users and 59 guests
