[Resolved] Not all users have access to main media folder
Postby lovebags » Fri Aug 07, 2015 12:05 pm
Since doing the 5.2 upgrade I've now got some LDAP users with no access to the main media folder. When I view certain users settings, the folder "Allow access to these media folders" is unchecked. However for other users, it is checked. I thought it might be new users who might not have access after the upgrade but when I deleted and then recreated an account on login, it had access.
We have over 2000 users so it would be cumbersome to manually check each one in the web interface. Does anyone have any thoughts as to why this may have occurred?
Next week I'll check with one of our other admins and see if we can't do a bulk change of the media folder setting.
Subsonic Version: 5.2.1 (build 4428) – March 4, 2015
Server Version: jetty-6.1.x, java 1.7.0_60, Windows Server 2008 R2 (176.0 MB / 292.5 MB)
Hardware Platform: VM
Java Memory Limit: 1024
lovebags
Re: Not all users have access to main media folder
Postby lovebags » Tue Aug 11, 2015 1:30 pm
On further evaluation it seems to be affecting only new LDAP users but I need to test this on a duplicate server to double check. I wonder if it's one of those issues with certain default LDAP settings in Subsonic that can't be changed for new users...
lovebags
Postby mrfloppy » Tue Aug 11, 2015 2:09 pm
I think revision #4459 should fix this.
Bugfix: Grant access to media folders when auto-creating LDAP users.
You can build your own version or wait for the 5.3 release.
mrfloppy
Postby lovebags » Thu Aug 13, 2015 11:18 am
awesome, thanks for pointing that out. Might roll back to 5.1 in the meantime.
lovebags
Users browsing this forum: No registered users and 67 guests
