Unable to start subsonic
Postby sweinst » Sun Aug 09, 2015 12:37 am
I've upgraded my PC to Windows 10 and subsonic stopped working.
I've re-installed it several times and I've updated java but it's still not working.
The service log shows:
10 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@1f25725: display name [org.springframework.context.support.ClassPathXmlApplicationContext@1f25725]; startup date [Sun Aug 09 01:31:56 BST 2015]; root of context hierarchy
37 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
204 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@1f25725]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1c248bf
209 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1c248bf: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
224 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: C:\Program Files (x86)\Subsonic\subsonic.war
Extracting webapp to c:\subsonic\jetty\4428
242 [main] INFO org.mortbay.log - jetty-6.1.x
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/C:/Program%20Files%20(x86)/Subsonic/subsonic-booter-jar-with-dependencies.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/C:/subsonic/jetty/4428/webapp/WEB-INF/lib/slf4j-log4j12-1.6.1.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
497 [main] INFO / - Initializing Spring root WebApplicationContext
497 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
510 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@f9dad2: display name [Root WebApplicationContext]; startup date [Sun Aug 09 01:31:57 BST 2015]; root of context hierarchy
532 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
569 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
583 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
590 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-sonos.xml]
601 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/cxf.xml]
607 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/cxf-servlet.xml]
677 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@f9dad2]: org.springframework.beans.factory.support.DefaultListableBeanFactory@627124
770 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@627124: defining beans [playerDao,mediaFileDao,artistDao,albumDao,playlistDao,playQueueDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,bookmarkDao,daoHelper,mediaFileService,securityService,settingsService,mediaScannerService,searchService,networkService,playerService,playlistService,versionService,statusService,ratingService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,folderBasedContentDirectory,upnpService,lastFmService,sonosService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlayQueueService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxStarService,ajaxTagService,ajaxTransferService,ajaxChatService,localeResolver,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheFactory,userCache,mediaFileMemoryCache,cxf,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,org.apache.cxf.bus.spring.BusExtensionPostProcessor,sonosEndpoint,sonosHelper]; root of factory hierarchy
781 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
1426 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@627124: defining beans [playerDao,mediaFileDao,artistDao,albumDao,playlistDao,playQueueDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,bookmarkDao,daoHelper,mediaFileService,securityService,settingsService,mediaScannerService,searchService,networkService,playerService,playlistService,versionService,statusService,ratingService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,folderBasedContentDirectory,upnpService,lastFmService,sonosService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlayQueueService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxStarService,ajaxTagService,ajaxTransferService,ajaxChatService,localeResolver,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheFactory,userCache,mediaFileMemoryCache,cxf,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,org.apache.cxf.bus.spring.BusExtensionPostProcessor,sonosEndpoint,sonosHelper]; root of factory hierarchy
1430 [main] WARN org.springframework.beans.factory.support.DisposableBeanAdapter - Invocation of destroy method 'shutdown' failed on bean with name 'cxf': org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'ajaxTagServiceSecure': Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
1430 [main] ERROR org.springframework.web.context.ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'mediaFileService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'metaDataParserFactory' while setting bean property 'metaDataParserFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'metaDataParserFactory' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot create inner bean 'net.sourceforge.subsonic.service.metadata.FFmpegParser#1ed67c4' of type [net.sourceforge.subsonic.service.metadata.FFmpegParser] while setting bean property 'parsers' with key [1]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#1ed67c4' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: java.io.IOException: org.hsqldb.HsqlException: Unexpected token:
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:135)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'metaDataParserFactory' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot create inner bean 'net.sourceforge.subsonic.service.metadata.FFmpegParser#1ed67c4' of type [net.sourceforge.subsonic.service.metadata.FFmpegParser] while setting bean property 'parsers' with key [1]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#1ed67c4' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: java.io.IOException: org.hsqldb.HsqlException: Unexpected token:
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:230)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:117)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedList(BeanDefinitionValueResolver.java:287)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:126)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
... 59 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#1ed67c4' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: java.io.IOException: org.hsqldb.HsqlException: Unexpected token:
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:219)
... 74 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: java.io.IOException: org.hsqldb.HsqlException: Unexpected token:
... 82 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: java.io.IOException: org.hsqldb.HsqlException: Unexpected token:
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1338)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
... 95 more
Caused by: org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: java.io.IOException: org.hsqldb.HsqlException: Unexpected token:
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:577)
at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:81)
at net.sourceforge.subsonic.dao.PlayerDao.deleteOldPlayers(PlayerDao.java:132)
at net.sourceforge.subsonic.service.PlayerService.init(PlayerService.java:57)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1414)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1375)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335)
... 105 more
Caused by: java.sql.SQLException: File input/output error: java.io.IOException: org.hsqldb.HsqlException: Unexpected token:
at java.sql.DriverManager.getConnection(Unknown Source)
... 119 more
1437 [main] ERROR org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@18cd1ae{/,jar:file:/C:/Program%20Files%20(x86)/Subsonic/subsonic.war!/}
... 59 more
Any idea on how to solve that?
Serge
sweinst
Re: Unable to start subsonic
Postby changelin » Wed Aug 12, 2015 2:03 am
I actually came here to post the exact same issue. After upgrading to Windows 10 Subsonic will refuse to start, even after manually trying to start it. I have noticed that if I reboot a couple times the server will start to work. But as soon as I reboot again the server refuses to start again.
changelin
Postby changelin » Sun Aug 16, 2015 2:52 pm
I must say that this issue is getting frustrating. Windows 10 downloads updates and reboots automatically without waiting, so I often come back to my PC with the Subsonic server unable to connect after an update. I usually have to reboot my PC at the very least once more (usually multiple times) to get Subsonic to work again. Does anyone have a fix/workaround for this issue? Is there some new setting that can be changed in W10?
changelin
Postby alphawave7 » Mon Aug 17, 2015 6:32 am
changelin wrote:I must say that this issue is getting frustrating. Windows 10 downloads updates and reboots automatically without waiting, so I often come back to my PC with the Subsonic server unable to connect after an update. I usually have to reboot my PC at the very least once more (usually multiple times) to get Subsonic to work again. Does anyone have a fix/workaround for this issue? Is there some new setting that can be changed in W10?
YES! In Settings-Update and Security-Windows Update, choose Advanced and set to 'Notify to Schedule Restart'..this prevents the autoboot.
Postby changelin » Tue Aug 18, 2015 11:18 pm
I tried this and Subsonic is still unable to connect after a reboot. Any other ideas?
changelin
Postby cwalger » Mon Nov 30, 2015 7:58 pm
I had my max mem set to 2000MB and had to lower it to < about 1000MB to start the server. I was getting the 1067 error when i tried to start the service.
I reinstalled java, reinstalled subsonic, ... but with max mem set above around 1000MB, the service wouldn't start.
I have 4GB RAM, and about 100k songs.
It works great now, with max mem set to 800.
cwalger
Users browsing this forum: No registered users and 125 guests
