Skipping music not available
Postby mathrb » Fri Aug 14, 2015 2:49 pm
I'm new with subsonic system.
I've got errors on several musics, player don't start the music. here are corresponding logs :
[2015-08-14 14:47:52,518] INFO PlayQueueInputStream - admin listening to "!!!!!!!!!!!!compile 02/03 Why Should I Cry.wma"
[2015-08-14 14:47:52,588] INFO TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/mnt/dd/musique_variee/!!!!!!!!!!!!compile 02/03 Why Should I Cry.wma] [-map] [0:0] [-b:a] [192k] [-v] [0] [-f] [mp3] [-]
[2015-08-14 14:47:52,613] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) /var/subsonic/transcode/ffmpeg: 1: /var/subsonic/transcode/ffmpeg: Syntax error: "(" unexpected
First question : does that mean that music file is corrupted or not recognized by subsonic
Second question : is there any way to auto skip files that cause that error ?
mathrb
Re: Skipping music not available
Postby brace011 » Sat Apr 23, 2016 6:22 pm
I have the same issues and I think it must be with ffmpeg. These same music files play fine on my subsonic server on Ubuntu but no longer play on a new server I built on FreeBSD.
[2016-04-23 14:14:19,480] DEBUG StreamController - GET /stream?player=128&id=310680&auth=2062241754, Range: bytes=0-
[2016-04-23 14:14:19,481] DEBUG StreamController - Content-Length: 7640000
[2016-04-23 14:14:19,481] DEBUG StreamController - Content-Range: 0-7639999/7640000
[2016-04-23 14:14:19,484] INFO TranscodeInputStream - Starting transcoder: /var/db/subsonic/transcode/ffmpeg -i /var/music/Nahko and Medicine for the People/2015 - On The Verge/1 - Nahko and Medicine for the People - Mitakuye Oyasin .m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[2016-04-23 14:14:19,485] INFO InputStreamReaderThread - (/var/db/subsonic/transcode/ffmpeg) /var/db/subsonic/transcode/ffmpeg: 1: Syntax error: "(" unexpected
brace011
