FreeNas Subsonic not displaying albums
Postby IrishGodfather » Sat Aug 15, 2015 10:44 pm
Had to reinstall FreeNas setup jail for subsonic, site loads no issues set storage for the jail to point to my music and mount it to /mnt/Music. Setup music library in subsonic to /mnt/Music scans all of my music (131gb) displays stats on files but subsonic does not display any albums, artists, or anything.
Deleted jail and recreated with same results :?
Browse subsonic jail storage via Sftp and can view all files
Has anyone seen this?
Version 5.2.1 (build 4427) – March 4, 2015
Server jetty-6.1.x, java 1.7.0_65, FreeBSD (58.3 MB / 202.0 MB)
Terms of use GPL 3.0 Subsonic is free software distributed under the GPL open-source license. Subsonic uses licensed third-party libraries. Please note that Subsonic is not a tool for illegal distribution of copyrighted material. Always pay attention to and follow the relevant laws specific to your country.
Homepage subsonic.org
Forum forum.subsonic.org
Contact Subsonic is developed and maintained by Sindre Mehus (sindre@activeobjects.no). If you have any questions, comments or suggestions for improvements, please visit the Subsonic Forum.
Log
[8/15/15 2:03:01 PM EDT] INFO MediaScannerService Scanned media library with 21750 entries.
[8/15/15 2:03:01 PM EDT] INFO MediaScannerService Scanned media library with 22000 entries.
Problem Description: (A clear description of the problem including any error messages that you received in your playback application)
Troubleshooting Steps: (A list of the steps you have taken to try to solve this problem yourself)
Playback Application and version: (The end application that you are using to stream from Subsonic)
Subsonic Version: (copy/paste from the "About" screen in the Subsonic Web Interface)
Server Version: (copy/paste from the "About" screen in the Subsonic Web Interface)
Hardware Platform: (Windows, Mac, Linux, NAS Model, etc... Invclude version if applicable)
Java Memory Limit: (Windows: found in the Subsonic Agent in the taskbar)
Problem Filename: (If you are having difficulty with a particular file, please include it's name)
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
Last ten log file lines: (The last ten or so lines copied and pasted from the About screen in the Subsonic Web Interface. Ideally these will be in a CODE block as well.)
IrishGodfather
Re: FreeNas Subsonic not displaying albums
Postby alphawave7 » Sat Aug 15, 2015 11:01 pm
Recent release requires even the admin to give themselves permissions in settings..then artist/albums should appear.
Postby IrishGodfather » Sun Aug 16, 2015 7:10 pm
Wow that's what it was, why would An admin not want access to the libraries? In any event I have my subsonic working again! Thank you!!!
alphawave7 wrote:Recent release requires even the admin to give themselves permissions in settings..then artist/albums should appear.
IrishGodfather
