Subsonic error
Subsonic error
Postby erichduff » Tue Aug 18, 2015 2:47 am
Hi. I've posted this once before. No response, so I'm posting again. Subsonic has bricked for me. I can't do anything with it. I get the following error screen (which tells me to post it here). Do the devs read these forums? Would greatly appreciate a response as I cannot use Subsonic at all any more because of this issue. Thanks. (p.s. I'm running Windows 10, though it was giving me this error before last week, when I was running Windows 7.
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
Java version Oracle Corporation 1.8.0_31
Operating system Windows 8 6.2
Server jetty-6.1.x
Memory Used 22 of 116 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:97)
at net.sourceforge.subsonic.dao.MediaFileDao.getChildrenOf(MediaFileDao.java:85)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:197)
at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:181)
at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:63)
at net.sourceforge.subsonic.service.MusicIndexService.getMusicFolderContent(MusicIndexService.java:73)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:131)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:135)
Caused by: java.sql.SQLException: out of memory
... 64 more
erichduff
Re: Subsonic error
Postby alphawave7 » Tue Aug 18, 2015 4:18 am
A workaround to this issue is to open Subsonic Control Panel, Settings Tab, change Memory Limit to 250 (or more if already set).
Re: Subsonic error
Postby andreasdevig » Wed Sep 16, 2015 9:38 am
alphawave7, where is the memory limit setting? Can you be more specific please? Is it at settings > advance > cover art limit? Download limit? Upload limit? Non-SSL stream port? I set them all to 250, yet no change. Is it at Settings > player > max bitrate? I set it to 256.
andreasdevig
Re: Subsonic error
Postby andreasdevig » Thu Oct 01, 2015 2:00 am
Tried deleting your folders from your subsonic account on the website, then purging anything named subsonic from your computer, then installing subsonic again? The premiumship will be lost, so it might be good if you still have your subsonic licence key.
andreasdevig
