Transcode error Mac OS 10.6
Postby cyrus » Sun Aug 23, 2015 8:35 pm
I've set up a server on a Mac mini running snow leopard 10.6 (subsonic 5.1). All is fine with the exception of transcoding of ogg files which fails with the following error message in the log:
"/Library/Application Support/Subsonic/transcode/ffmpeg": error=86, Bad CPU type in executable
I'm struggling to find a solution to this and would be grateful if anyone has experienced this and found a solution could share the solution with me
Many thanks
Cyrus
cyrus
Re: Transcode error Mac OS 10.6
Postby alphawave7 » Sun Aug 23, 2015 8:51 pm
Not a Mac user, but you could try updating ffmpeg in the transcode folder:
http://ffmpegmac.net/
Postby cyrus » Mon Aug 24, 2015 7:04 am
Thanks for the suggestion. I've given that a shot and have replaced the version of ffmpeg in the transcode folder with this one. Still getting the same error message. Will probably need to go back to square one and try a step by step reinstall.
cyrus
Postby cyrus » Fri Sep 04, 2015 4:30 am
Actually really easy solution - I tried the version for leopard (I have snow leopard) and that worked, so problem solved. Thanks
cyrus
Postby alphawave7 » Fri Sep 04, 2015 5:45 am
cyrus wrote:Actually really easy solution - I tried the version for leopard (I have snow leopard) and that worked, so problem solved. Thanks
Excellent..Thanks for reporting back. Cheers!
Users browsing this forum: No registered users and 60 guests
