can not stream subsonic over 3G, remote wifi works fine
Postby mimoun » Sun Aug 23, 2015 8:50 pm
I have set up subsonic porperly ,have forwarded ports 4040. i am able to stream on my local network. and have no problems with remote acces/streaming over WIFI.
I have installed the android app. the demo server in the app connects to subsonic. however when i added my server addres and password and username i could not connect to subsonic.
if anyone can help me fix this i would be happy.
PS: apologies for my poor english i am new here and i speak dutch
mimoun
Re: can not stream subsonic over 3G, remote wifi works fine
Postby alphawave7 » Sun Aug 23, 2015 8:58 pm
Try a router reboot. When you say 'remote/wifi' works, do you mean outside your lan? Often this is a router issue forwarding the port properly. Recall that Subsonic must be running to test.
