Subsonic Scrobbling no longer working?
Postby d3ngar » Sat Sep 05, 2015 11:31 am
I noticed that the subsonic scrobbling isn't working anymore.
I know that Last.fm recently upgraded their application and so I tried logging out (disabled scrobbling) and then reconnecting. This didn't do the trick.
Can someone else confirm that this is an issue? According to Last.fm the last time I scrobbled was 27th of August. I must have scrobbled since then, I use Subsonic at work quite often.
Chris
d3ngar
Re: Subsonic Scrobbling no longer working?
Postby maexwell » Wed Sep 09, 2015 1:11 pm
Same problem here. It came with the last.fm update.
[9/9/15 2:58:28 PM EEST]   WARN   AudioScrobblerService   Failed to scrobble song '' at Last.fm. Bad timestamp, please check local clock.
I use only subsonic for listening music and I really like to have some stats about my listening.
Edit:
Ok finally accessed my server and my clock was 4mins off. :oops:
Maybe last.fm is more strict about it after their update.
maexwell
Postby seir » Thu Sep 10, 2015 8:17 pm
maexwell wrote:Ok finally accessed my server and my clock was 4mins off. :oops:
Thanks a bunch! :D This solved the problem I had with scrobbling.
The hw clock on my server is about 8 minutes off :?
seir
Postby williamsdb » Fri Sep 18, 2015 8:15 am
Thanks that worked for me too!
williamsdb
