Internal error trying to view some folders
Postby dantal33 » Mon Sep 14, 2015 10:38 am
When trying to view some of the folders in my main music folder I am getting an error. I am browsing by letter in my main music folder. Most are working fine, but a select few are getting the following error.
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
Java version Oracle Corporation 1.8.0_31
Server jetty-6.1.x
Memory Used 30 of 144 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:97)
at net.sourceforge.subsonic.dao.MediaFileDao.getChildrenOf(MediaFileDao.java:85)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:197)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:174)
at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:92)
Caused by: java.sql.SQLException: out of memory
... 62 more
dantal33
Re: Internal error trying to view some folders
Postby andreasdevig » Thu Oct 01, 2015 2:00 am
Tried deleting your folders from your subsonic account on the website, then purging anything named subsonic from your computer, then installing subsonic again? The premiumship will be lost, so it might be good if you still have your subsonic licence key.
andreasdevig
