Add networked media folder.
Postby jay_uk » Sun Sep 20, 2015 11:18 am
I have set up a Raspberry Pi to run subsonic, however all my music is on my windows machine. These folders are shared via windows network. How do I add these locations to subsonic so that it can scan them? I have tried entering the folder location as "\\WINMACHINE\Audio\Music" but i get is folder not found. Do I need to enable samba?
Basically how do you add network folders to subsonic.
jay_uk
Re: Add networked media folder.
Postby arson714 » Mon Sep 21, 2015 6:26 pm
It sounds like the user you are trying to access the share with doesn't have permissions to your network folder. I have a similar setup (Raspberry Pi running subsonic and connecting to a NAS). I had this same problem until I sorted out permissions to where the account logged on to the Raspberry Pi did not have access to the music folder on the NAS.
arson714
Postby jay_uk » Tue Sep 22, 2015 2:43 pm
arson714 wrote:It sounds like the user you are trying to access the share with doesn't have permissions to your network folder. I have a similar setup (Raspberry Pi running subsonic and connecting to a NAS). I had this same problem until I sorted out permissions to where the account logged on to the Raspberry Pi did not have access to the music folder on the NAS.
The folder is on a windows machine. Permissions are set to anyone can view/read. Other machines on the network can see the and play the contents of the folder.
jay_uk
Postby lpr » Tue Sep 22, 2015 3:32 pm
I had a similar problem.
viewtopic.php?f=4&t=15899&start=15#p68541
The format is like this:
\\NAS\music\folder
lpr
