Solved: help with my DD-WRT router setup
Postby kermit22 » Fri Feb 20, 2009 7:04 pm
Hi there. I just installed Subsonic as a replacement to VibeStreamer and i'm having some trouble connecting from outside my LAN. I uninstalled VibeStreamer and changed the Subsonic listening port from 80 to 8081 so that i wouldn't have to change my router configuration but I am unable to connect. I can connect internally when i type 192.168.1.5:8081. I have a DDNS account that is similar to myserver.blogsite.org and i did port forwarding from port 80 outside to 8081 inside but i am still unable to connect. Anyone have any ideas?
kermit22
Postby kermit22 » Fri Feb 20, 2009 8:58 pm
It wasn't my DD-wrt setup that was causing the issues. It was my Windows firewall not allowing Subsonic the access that it needed.
kermit22
