HTTP ERROR: 503 (again)
Postby 808Hunter » Wed Sep 30, 2015 9:25 pm
This is the forth time in the last few months I have received HTTP ERROR: 503
Very aggravating.
Subsonic starts to work for a few days and then BAM. 503
Any thoughts?
808Hunter
Re: HTTP ERROR: 503 (again)
Postby noleech » Wed Sep 30, 2015 9:52 pm
HTTP Error 503 - Service unavailable
Introduction
The Web server (running the Web site) is currently unable to handle the HTTP request due to a temporary overloading or maintenance of the server. The implication is that this is a temporary condition which will be alleviated after some delay. Some servers in this state may also simply refuse the socket connection, in which case a different error may be generated because the socket creation timed out.
Fixing 503 errors
The Web server is effectively 'closed for repair'. It is still functioning minimally because it can at least respond with a 503 status code, but full service is impossible i.e. the Web site is simply unavailable. There are a myriad possible reasons for this, but generally it is because of some human intervention by the operators of the Web server machine. You can usually expect that someone is working on the problem, and normal service will resume as soon as possible.
Please contact the system operators of the Web site (e.g. your ISP) to determine why the service is down. They will be in a much better position to help you than we are for this type of error.
503 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle when it communicates with the Web server:
Obtain an IP address from the IP name of the site (the site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
Open an IP socket connection to that IP address.
Write an HTTP data stream through that socket.
Receive an HTTP data stream back from the Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognizes as '503'.
Please post your Subsonic version, server specs, and how you access you music server (local access within the LAN or from the internet WAN) any port forwarding. DON'T post your real Public IP address or you real website name.
Make sure you have enough processing resource for your server. Your Ethernet card on your server is functioning correctly......
noleech
