Web Address Not Registered
Postby bethesdaadk » Wed Oct 07, 2015 12:00 pm
Port forwarding is working as the setting states: "Status: Successfully forwarding port 4040."
However, the address I had been using in the past - but seems to have been lost says: "Status: Web address xxxxxx.subsonic.org not registered."
Have I lost that address? Do I just need to pick a new one? Is there a way to get the old one back?
bethesdaadk
Re: Web Address Not Registered
Postby alphawave7 » Wed Oct 07, 2015 2:32 pm
You need to verify port forwarding, not use the internal message. canyouseeme.org.
Postby bethesdaadk » Wed Oct 07, 2015 3:47 pm
Good tip.
Error: I could not see your service on xx.xx.xx.xx on port (4040)
Reason: Connection timed out
Your IP:
Port to Check:
I wonder why SubSonic was giving me a false positive.
bethesdaadk
Postby alphawave7 » Wed Oct 07, 2015 3:59 pm
bethesdaadk wrote:Good tip.
Your IP:
Port to Check:
I think it is only looking at itself, IOW it can see it is responding to its port on the server itself, not an external test.
Postby bethesdaadk » Wed Oct 07, 2015 4:14 pm
I think you are right. I was able to adjust my router config and now it's working.
Thanks.
bethesdaadk
