Service Unavailable Suddenly- Please help
Postby goblue30093 » Fri Oct 16, 2015 3:31 am
Problem Description: Everything has worked fine for months and then suddenly last week my phone could no longer find the server. I check my pc and if i right click on the tray icon and choose web browser subsonic it gives me a "error 503 service unavailable" error. If I go into the control panel it's up and running but i cannot get to localhost.
Not much I can do because i can't really change any settings.
Troubleshooting Steps: Not much I can do, I've done the usuals, restart pc, phone, etc.
Playback Application and version: Android Subsonic 4.4 on a Samsung galaxy s6 edge
Subsonic Version: 4.4
Server Version: Build # 4428
Hardware Platform: Windows 7 based laptop
Java Memory Limit: 150mb
Problem Filename: N/A
Output from ffmpeg -i: N/A
Last ten log file lines: 249 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@141a79c: display name [org.springframework.context.support.ClassPathXmlApplicationContext@141a79c]; startup date [Wed Oct 14 22:13:50 EDT 2015]; root of context hierarchy
530 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-agent.xml]
1171 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@141a79c]: org.springframework.beans.factory.support.DefaultListableBeanFactory@8806ef
1233 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@8806ef: defining beans [service,agent,frame,settingsPanel,statusPanel]; root of factory hierarchy
Executing: subsonic-service.exe -stop
Executing: subsonic-service.exe -start
10360 [pool-1-thread-1] WARN org.springframework.remoting.rmi.RmiProxyFactoryBean - Could not connect to RMI service [rmi://localhost:9412/SubsonicDeployerService] - retrying
2147596 [pool-1-thread-2] WARN org.springframework.remoting.rmi.RmiProxyFactoryBean - Could not connect to RMI service [rmi://localhost:9412/SubsonicDeployerService] - retrying
90069158 [pool-1-thread-1] WARN org.springframework.remoting.rmi.RmiProxyFactoryBean - Could not connect to RMI service [rmi://localhost:9412/SubsonicDeployerService] - retrying
Any help would be appreciated. Also I am a Premium user .. i bought the year license. Not sure if that makes a difference on settings, but its more info.
goblue30093
Re: Service Unavailable Suddenly- Please help
Postby goblue30093 » Wed Oct 21, 2015 1:53 pm
anyone????
goblue30093
Postby andreasdevig » Wed Oct 21, 2015 5:54 pm
I can't connect to the server either. I tried purging everything, and reinstalling, but it didn't seem to work this time. I don't know what to do.
andreasdevig
Postby noleech » Wed Oct 21, 2015 6:13 pm
WIKI -
503 Service Unavailable
The server is currently unavailable (because it is overloaded or down for maintenance). Generally, this is a temporary state
I would say something is causing the overload. How much Java Memory is subsonic using? If you have plenty of memory I suggest bumping it up. Typically 150 Mb should not affect you Subsonic. Something in your laptop is corrupting your Java is my guess. I would try to shut down subsonic service (thru service manager) or thru the subsonic control panel, then shut anything related to subsonic in the task manager. uninstall java and donwload the java again. then relaunch Subsonic.
noleech
Postby andreasdevig » Wed Nov 18, 2015 12:22 pm
Finally working for me again.
andreasdevig
Users browsing this forum: Google [Bot] and 17 guests
