Connection works via cellular but not Wifi
Postby don.antonow » Sun Oct 18, 2015 2:48 pm
I have been using subsonic for years and love it. Recently I have not been able to connect to the server from my iphone while in my house using wifi. If I switch wifi off, presto, Im connected. I use iSub to connect. Any ideas?
don.antonow
Re: Connection works via cellular but not Wifi
Postby alphawave7 » Sun Oct 18, 2015 6:57 pm
This often happens due to router 'loopback' issues. It sometimes can be fixed by updating router firmware or searching/fixing the loopback in firmware, or what I also do is have separate entries in Subsonic app-Home: use actual IP:4040, Away: use my custom url. HTH!
Postby don.antonow » Mon Oct 19, 2015 3:38 pm
Thanks! I just installed the latest Merlin Firmware and set Nat Loopback to ASUS. Works perfectly. :)
don.antonow
