clean CentOS 7 - subsonic won't work
Postby klm46 » Tue Oct 27, 2015 9:30 am
i got an SSD-Crash due to Electricityproblems at home. No i used this "chance" to set up an new CentOS 7 server. So after installation of the system, java with depencies and downloading and installing the 5.3-rpm i got no subsonic starting. No config-changes has been done yet. All the other installations i made, were working out of the box.
My System
uname -a
Linux klmserver 3.10.0-229.14.1.el7.x86_64 #1 SMP Tue Sep 15 15:05:51 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
subsonic_sh.log
31 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@5627f221: display name [org.springframework.context.support.ClassPathXmlApplicationContext@5627f221]; startup date [Tue Oct 27 10:23:06 CET 2015]; root of context hierarchy
99 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
523 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@5627f221]: org.springframework.beans.factory.support.DefaultListableBeanFactory@184ce1cd
538 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@184ce1cd: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
564 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: /usr/share/subsonic/subsonic.war
Extracting webapp to /var/subsonic/jetty/4568
603 [main] INFO org.mortbay.log - jetty-6.1.x
642 [main] INFO org.mortbay.log - Extract jar:file:/usr/share/subsonic/subsonic.war!/ to /var/subsonic/jetty/4568/webapp
[GC 15872K->4199K(57344K), 0,0070100 secs]
[GC 20071K->3524K(57344K), 0,0041400 secs]
[GC 19385K->4222K(57344K), 0,0047130 secs]
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/usr/share/subsonic/subsonic-booter-jar-with-dependencies.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/var/subsonic/jetty/4568/webapp/WEB-INF/lib/slf4j-log4j12-1.6.1.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
[GC 20094K->4080K(57344K), 0,0076350 secs]
Subsonic.log does not log anything.
Status:
# service subsonic status
subsonic.service - LSB: Subsonic daemon
Loaded: loaded (/etc/rc.d/init.d/subsonic)
Active: active (exited) since Di 2015-10-27 10:23:06 CET; 5min ago
Process: 2404 ExecStart=/etc/rc.d/init.d/subsonic start (code=exited, status=0/SUCCESS)
Okt 27 10:23:06 klmserver systemd[1]: Starting LSB: Subsonic daemon...
Okt 27 10:23:06 klmserver subsonic[2404]: Starting subsonic ...
Okt 27 10:23:06 klmserver su[2408]: (to root) root on none
Okt 27 10:23:06 klmserver subsonic[2404]: Started Subsonic [PID 2417, /var/subsonic/subsonic_sh.log]
Okt 27 10:23:06 klmserver systemd[1]: Started LSB: Subsonic daemon.
any ideas?
klm46
