No trace of DLs in the log
Postby cellulit » Wed Feb 25, 2009 4:39 pm
Hi.
I just found a strange issue with 3.6 that actually makes me think about putting it on hold for a while.
Recently I noticed a huge traffic and couple of connections to my subsonic. I found and confirmed that the IP connecting was a friend of mine. He was downloading a few albums. Fine, but the log file (\subsonic\subsonic.log) had no such activity indicated inside.
And just today another user told me he was downloading albums, while I shut down the server. I couldn't tell that, as the log was empty again.
Any idea what can be happening? The previous beta was just all right.
ps. I'm running it on windows xp and using the default installer.
Thnx.
.cell
cellulit
Postby sindre_mehus » Thu Feb 26, 2009 5:45 pm
Has anyone else seen this? I get the proper logging when downloading.
Postby cellulit » Thu Feb 26, 2009 11:54 pm
justa thought... Do you think you could add a more detailed logging in the next beta? For example a moment when people log into the site.
.cell
cellulit
Postby jannuh » Mon Mar 02, 2009 4:01 pm
Even more detailed?
Maybe better an error log and a separate d/l & userlogin log
Have the subsonic log always opened with Tail32
10.789 artiesten
9.211 albums
42.717 nummers
146,55 GB (~ 2.276 uur)
jannuh
Postby cellulit » Fri Mar 06, 2009 8:56 pm
i know it sounds crazy, but i'm experiencing a similar thing now again.
one of my friends swears he's listening to a track via Subsonic, and actually it's true as I can see his status on last.fm - Subsonic is there in "listening now". my instance.
nothing's in the log. the status is blind about it. the thing is some other actions are actually being logged, like download of that person.
what is this? a memory issue with writting to logs? an issue when simultanous actions are being conducted by one user? my setup only?
jus thinking at loud...
.cell
cellulit
Postby sindre_mehus » Sun Mar 08, 2009 10:09 am
It doesn't explain the last.fm thing, but I've noticed that if you play the same songs over again, the Flash player will cache them, so that they are not streamed from Subsonic again.
Postby cellulit » Sun Mar 08, 2009 10:23 am
maybe that's the reason. i'll keep an eye on it.
thanks.
.cell
cellulit
