Media library scan finds songs, no songs show in UI
Postby avaly » Sun Nov 15, 2015 12:41 pm
Problem Description:
Media library scanned and found audio files (showing count stats in the left column), but no songs appear in the UI: neither in the left column, nor in the "filters" on the Home page (e.g. "Recently added", "All").
Troubleshooting Steps: Restarted the subsonic service several times, performed several media library scans
Playback Application and version: The web application
Subsonic Version: 5.3 (build 4568) – October 24, 2015
Server Version: 5.3 (build 4568) – October 24, 2015
Hardware Platform: Ubuntu 14.04.3 LTS
Java Memory Limit: 200M
Output from ffmpeg -i:
$ ffmpeg -i /media/nas/music/classical/Antonio\ Vivaldi\ -\ The\ Four\ Seasons\ and\ Violin\ Concertos/01.\ Concerto\ No.\ 1\ In\ E\,\ Rv\ 269\ \'spring\'\ -\ I\ Allegro.mp3
ffmpeg version N-76045-g97be5d4 Copyright (c) 2000-2015 the FFmpeg developers
  built with gcc 4.8 (Ubuntu 4.8.4-2ubuntu1~14.04)
  configuration: --extra-libs=-ldl --prefix=/opt/ffmpeg --enable-avresample --disable-debug --enable-nonfree --enable-gpl --enable-version3 --enable-libopencore-amrnb --enable-libopencore-amrwb --disable-decoder=amrnb --disable-decoder=amrwb --enable-libpulse --enable-libdcadec --enable-libfreetype --enable-libx264 --enable-libx265 --enable-libfdk-aac --enable-libvorbis --enable-libmp3lame --enable-libopus --enable-libvpx --enable-libspeex --enable-libass --enable-avisynth --enable-libsoxr --enable-libxvid --enable-libvo-aacenc --enable-libvidstab
  libavutil      55.  4.100 / 55.  4.100
  libavcodec     57.  6.100 / 57.  6.100
  libavformat    57.  4.100 / 57.  4.100
  libavdevice    57.  0.100 / 57.  0.100
  libavfilter     6. 11.100 /  6. 11.100
  libavresample   3.  0.  0 /  3.  0.  0
  libswscale      4.  0.100 /  4.  0.100
  libswresample   2.  0.100 /  2.  0.100
  libpostproc    54.  0.100 / 54.  0.100
[mp3 @ 0x200a2e0] Skipping 0 bytes of junk at 5419.
Input #0, mp3, from '/media/nas/music/classical/Antonio Vivaldi - The Four Seasons and Violin Concertos/01. Concerto No. 1 In E, Rv 269 'spring' - I Allegro.mp3':
  Metadata:
    title           : Concerto No. 1 in E, RV 269 'Spring' - I: Allegro
    artist          : Itzhak Perlman
    album           : Vivaldi-The Four Seasons and Violin Concertos
    encoded_by      : Exact Audio Copy   (Secure mode)
    track           : 01/21
    genre           : Classical
    date            : 1725
  Duration: 00:03:22.81, start: 0.025057, bitrate: 320 kb/s
    Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 320 kb/s
    Metadata:
      encoder         : LAME3.97
    Side data:
      replaygain: track gain - -0.500000, track peak - unknown, album gain - unknown, album peak - unknown,
Last ten log file lines:
11/15/15 12:28:08 PM GMT]   INFO   MediaScannerService   Scanned media library with 8250 entries.
[11/15/15 12:28:10 PM GMT]   INFO   MediaScannerService   Scanned media library with 8500 entries.
[11/15/15 12:28:11 PM GMT]   INFO   MediaScannerService   Scanned media library with 8750 entries.
[11/15/15 12:28:12 PM GMT]   INFO   MediaScannerService   Scanned media library with 8927 entries.
[11/15/15 12:28:12 PM GMT]   INFO   MediaScannerService   Marking non-present files.
[11/15/15 12:28:13 PM GMT]   INFO   MediaScannerService   Marking non-present artists.
[11/15/15 12:28:13 PM GMT]   INFO   MediaScannerService   Marking non-present albums.
[11/15/15 12:28:13 PM GMT]   INFO   MediaScannerService   Completed media library scan.
[11/15/15 12:28:16 PM GMT]   INFO   PlaylistService   Starting playlist import.
[11/15/15 12:28:16 PM GMT]   INFO   PlaylistService   Completed playlist import.
This issue started after upgrading to version 5.3, previously on 4.8. After upgrading to 5.3, I had to remove the old DB folder and let the new version create a new one.
avaly
Re: Media library scan finds songs, no songs show in UI
Postby avaly » Sat Nov 21, 2015 8:19 pm
Found this answer in this thread: viewtopic.php?f=2&t=16139
avaly
Postby alphawave7 » Sat Nov 21, 2015 9:10 pm
avaly wrote:Found this answer in this thread: viewtopic.php?f=2&t=16139
Sorry avaly...when I skimmed your OP, I didn't read carefully enough and thought it might be a permissions issue on Ubuntu (and I would need to review that process in detail myself!), when the solution was simpler. Enjoy!
