No GUI after new install of 5.3
Postby Harry61 » Tue Nov 24, 2015 11:44 am
I installed a new instance on a VPS with subsonic 5.3
java 1.7.0-openjdk is installed
no graphical use interface will be display by entering http://server1.domain.extension:4040?
I get only this
Directory: /
WEB-INF/ 40 bytes Nov 24, 2015 12:30:36 PM
ad/ 25 bytes Nov 24, 2015 12:30:37 PM
crossdomain.xml 203 bytes Oct 18, 2015 8:49:50 AM
error.jsp 2225 bytes Oct 18, 2015 8:49:50 AM
flash/ 83 bytes Nov 24, 2015 12:30:37 PM
icons/ 4096 bytes Nov 24, 2015 12:30:37 PM
script/ 78 bytes Nov 24, 2015 12:30:36 PM
sonos/ 6 bytes Nov 24, 2015 12:30:37 PM
style/ 23 bytes Nov 24, 2015 12:30:36 PM
and in the logfile there is this message:
24 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@189a2557: display name [org.springframework.context.support.ClassPathXmlApplicationContext@189a2557]; startup date [Tue Nov 24 12:41:40 CET 2015]; root of context hierarchy
74 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
401 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@189a2557]: org.springframework.beans.factory.support.DefaultListableBeanFactory@afe1bc5
414 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@afe1bc5: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
436 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: /usr/share/subsonic/subsonic.war
Extracting webapp to /var/subsonic/jetty/4568
469 [main] INFO org.mortbay.log - jetty-6.1.x
613 [main] WARN org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@147c0b3f{/,jar:file:/usr/share/subsonic/subsonic.war!/}
java.util.zip.ZipException: zip file is empty
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:215)
at java.util.zip.ZipFile.<init>(ZipFile.java:145)
at java.util.jar.JarFile.<init>(JarFile.java:154)
at java.util.jar.JarFile.<init>(JarFile.java:118)
at org.mortbay.jetty.webapp.TagLibConfiguration.configureWebApp(TagLibConfiguration.java:171)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1215)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:135)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
644 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
694 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
725 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
760 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[109.201.155.161:9412](local),objID:[0:0:0, 0]]]]
what do i wrong?
Many thx for your replies
Harry
Harry61
