Win 10 upgrade: Service won't start, only Control Panel.
Postby MaLaCoiD » Mon Nov 30, 2015 7:14 am
Problem Description: (A clear description of the problem including any error messages that you received in your playback application)
MaL: I just upgraded from Windows 7 to Windows 10 and my OS appears to be intact. But Subsonic Service won't start.
Troubleshooting Steps: (A list of the steps you have taken to try to solve this problem yourself)
MaL: Rebooted PC. Verified I'm using latest Server 5.3 and Java 8u66. Changed ports from 42080/42443 to 4041/4042. Renamed C:\Subsonic\db to db.backup.
Playback Application and version: (The end application that you are using to stream from Subsonic)
MaL: N/A
Subsonic Version: (copy/paste from the "About" screen in the Subsonic Web Interface)
Server Version: (copy/paste from the "About" screen in the Subsonic Web Interface)
MaL: 5.3- can only run Subsonic Control Panel (aka Agent)
Hardware Platform: (Windows, Mac, Linux, NAS Model, etc... Include version if applicable)
MaL: Windows 10 Desktop.
Java Memory Limit: (Windows: found in the Subsonic Agent in the taskbar)
MaL: 1500
Problem Filename: (If you are having difficulty with a particular file, please include it's name)
MaL: N/A
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
MaL: N/A
Last ten log file lines: (The last ten or so lines copied and pasted from the About screen in the Subsonic Web Interface. Ideally these will be in a CODE block as well.)
MaL: Can only run Subsonic Control Panel. Log last updated before the upgrade:
[2015-11-25 07:00:38,436] INFO DaoHelper - Checking database schema.
[2015-11-25 07:00:42,139] INFO DaoHelper - Done checking database schema.
[2015-11-25 07:00:42,654] INFO VersionService - Resolved local Subsonic version to: 5.2.1
[2015-11-25 07:00:43,248] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Thu Nov 26 03:00:00 PST 2015
[2015-11-25 07:00:43,357] INFO UPnPService - Starting UPnP service...
[2015-11-25 07:00:43,467] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Wed Nov 25 07:05:43 PST 2015
[2015-11-25 07:00:43,857] INFO UPnPService - Enabling UPnP/DLNA media server
[2015-11-25 07:00:43,857] INFO UPnPService - Starting UPnP service - Done!
[2015-11-25 07:00:51,670] INFO SonosService - No Sonos controller found
[2015-11-25 07:03:09,228] INFO NetworkService - Deleted port mapping for port 42080
[2015-11-25 07:05:17,273] INFO NetworkService - Deleted port mapping for port 42443
[2015-11-25 07:05:43,492] INFO PodcastService - Starting scheduled Podcast refresh.
[2015-11-25 07:05:43,492] INFO PodcastService - Completed scheduled Podcast refresh.
MaLaCoiD
Re: Win 10 upgrade: Service won't start, only Control Panel.
Postby MaLaCoiD » Mon Nov 30, 2015 10:46 pm
I found a solution in another tread... I changed Memory Limit from 1500 to 800.
http://forum.subsonic.org/forum/viewtopic.php?f=2&t=15872&sid=50035bca3ea08244161146937d323d46#p69481
Gracias, cwalger!
MaLaCoiD
