db lock file
db lock file
Postby spookybathtub » Wed Dec 02, 2015 9:32 pm
Since updating to version 5.3, I have a mysterious entry in subsonic.log every time I start it up. It thinks the database is already in use. But I verify each time before starting the service that the subsonic.lck file does not exist. That file is created when I start the service, and it is removed when I stop the service. The weird thing is, the last line of that log file says I'm still running 5.1, but the web browser GUI correctly shows 5.3.
I'm running Subsonic 5.3 release on Tomcat 7.0.52 on Ubuntu 14.04.
[2015-12-02 13:22:35,652] INFO DaoHelper - Checking database schema.
[2015-12-02 13:22:36,224] ERROR DaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@2d6451a6[file =/var/subsonic/db/subsonic.lck, exists=true, locked=false, valid=false, fl =null]: java.lang.Exception: checkHeartbeat(): lock file [/var/subsonic/db/subsonic.lck] is presumably locked by another process.
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:429)
   at net.sourceforge.subsonic.dao.schema.Schema25.execute(Schema25.java:38)
   at net.sour[2015-12-02 13:22:42,180] INFO BootstrapVerificationFilter - Servlet container: Apache Tomcat/7.0.52 (Ubuntu)
nit>(DaoHelper.java:73)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
   at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
   at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4973)
   at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5467)
   at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
   at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
   at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
   at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:632)
   at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1229)
   at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1875)
   at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
   at java.util.concurrent.FutureTask.run(FutureTask.java:262)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
   at java.lang.Thread.run(Thread.java:745)
Caused by: java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@2d6451a6[file =/var/subsonic/db/subsonic.lck, exists=true, locked=false, valid=false, fl =null]: java.lang.Exception: checkHeartbeat(): lock file [/var/subsonic/db/subsonic.lck] is presumably locked by another process.
   at java.sql.DriverManager.getConnection(DriverManager.java:571)
   at java.sql.DriverManager.getConnection(DriverManager.java:187)
   ... 54 more
[2015-12-02 13:22:37,038] INFO VersionService - Resolved local Subsonic version to: 5.1
spookybathtub
