Can not select USB folder on RP2
Postby Waredan » Sun Dec 06, 2015 6:51 pm
I have a Raspberry Pi 2 and installed Subsonic succesfully on my RP2. I can open the subsonic page in my browser from another computer in my network.
The problem I have is that I can not select my 16 GB Sandisk Cruzer USB 2.0 driver in the Subsonic settings page as my music folder.
The folder after the name "USB" is the folder that I am using. You can see here that it says "folder not found" Image
On my RP2 I did a "pwd" to print the directory of my USB. You can see that I have typed the same directory. Image
Thanks in advance!
Waredan
Re: Can not select USB folder on RP2
Postby sindre_mehus » Tue Dec 15, 2015 7:37 pm
Please check that the Linux user running Subsonic has read access to the directory.
