INTERNAL ERROR PLEASE HELP
Postby geo97 » Sun Dec 06, 2015 8:31 pm
    Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
    Java version Oracle Corporation 1.8.0_31
    Server jetty-6.1.x
    Memory Used 56 of 1328 MB
    Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
    at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:666)
    at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:698)
    at org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate.query(NamedParameterJdbcTemplate.java:133)
    at org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate.query(NamedParameterJdbcTemplate.java:137)
    at net.sourceforge.subsonic.dao.AbstractDao.namedQuery(AbstractDao.java:104)
    at net.sourceforge.subsonic.dao.MediaFileDao.getNewestAlbums(MediaFileDao.java:280)
    at net.sourceforge.subsonic.service.MediaFileService.getNewestAlbums(MediaFileService.java:276)
    at net.sourceforge.subsonic.controller.HomeController.getNewest(HomeController.java:180)
    at net.sourceforge.subsonic.controller.HomeController.handleRequestInternal(HomeController.java:100)
    at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:47)
    at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:59)
    Caused by: java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
    ... 65 more
geo97
Re: INTERNAL ERROR PLEASE HELP
Postby alphawave7 » Sun Dec 06, 2015 10:23 pm
Search forum for S1000 error for the solution. ALWAYS manually shut down Subsonic before updating Java.
