DISCONNECT SET SCHEMA PUBLIC
Postby HaaTa » Wed Dec 09, 2015 2:18 am
Fresh re-install of Subsonic (Arch Linux system).
Subsonic doesn't seem to start the web ui, just keeps trying to set schema public...
Logs don't report any failures or errors.
I haven't imported any settings yet.
/*C760*/DISCONNECT
/*C762*/SET SCHEMA PUBLIC
CONNECT USER SA
/*C763*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C762*/DISCONNECT
/*C764*/SET SCHEMA PUBLIC
CONNECT USER SA
/*C765*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C764*/DISCONNECT
/*C766*/SET SCHEMA PUBLIC
CONNECT USER SA
/*C767*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C766*/DISCONNECT
/*C768*/SET SCHEMA PUBLIC
CONNECT USER SA
/*C769*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C768*/DISCONNECT
The logs just keep filling up. Restarting subsonic does not help.
HaaTa
