Upload zips, Subsonic not finding music
Postby TheEternalAbyss » Tue Dec 15, 2015 6:02 am
Problem Description: So the general issue I am having is that I uploaded several zip files/albums through Subsonic's web interface, yet no matter how many times I refresh or force a re-scan of my library, I still do not see the uploaded files.
Troubleshooting Steps: I have performed several scans, licked refresh multiple times, logged out and then in again, cleared cache of my browser, went on my server directly stopping the service and restarting it. Scanned again on the server itself. Yet still... new music is not added, not searchable nor can I click to it from the web interface.
Playback Application and version: (The end application that you are using to stream from Subsonic)
Subsonic Version: 5.3 (build 4569) – October 25, 2015
Server Version: jetty-6.1.x, java 1.8.0_66, Windows 10 (89.7 MB / 142.3 MB)
Hardware Platform: Windows 10
Java Memory Limit: 2000
Problem Filename: no particular file name.. the directory structure for my music is an external enclosure, with 4 HDs, that raid each other essentially.
Output from ffmpeg -i: I don't have one filename in particular for this, but I can try to use it on one of the files I tried to add. I can not do it this moment but I can update ths post as soon as I can.
Last ten log file lines:
[12/14/15 10:11:47 PM EST]    INFO   MediaScannerService   Scanned media library with 47500 entries.
[12/14/15 10:11:49 PM EST]    INFO   MediaScannerService   Scanned media library with 47750 entries.
[12/14/15 10:11:51 PM EST]    INFO   MediaScannerService   Scanned media library with 48000 entries.
[12/14/15 10:11:51 PM EST]    INFO   MediaScannerService   Scanned media library with 48056 entries.
[12/14/15 10:11:51 PM EST]    INFO   MediaScannerService   Marking non-present files.
[12/14/15 10:12:03 PM EST]    INFO   MediaScannerService   Marking non-present artists.
[12/14/15 10:12:04 PM EST]    INFO   MediaScannerService   Marking non-present albums.
[12/14/15 10:12:05 PM EST]    INFO   MediaScannerService   Completed media library scan.
[12/14/15 10:12:06 PM EST]    INFO   PlaylistService   Starting playlist import.
[12/14/15 10:12:06 PM EST]    INFO   PlaylistService   Completed playlist import.
Has anyone experienced the same issue? Thank you in advance for any assistance you can provide.
TheEternalAbyss
