(RESOLVED) Error Message
Postby jgraythe4th » Sun Jan 10, 2016 11:55 pm
I just rebuilt the database with all my settings and users. Its working like new again.....as it should.
I'm getting this error message in the left column where all of my music should be. Can anyone help me out?
Error
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
Java version Oracle Corporation 1.8.0_66
Operating system Windows 10 10.0
Server jetty-6.1.x
Memory Used 285 of 494 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:97)
at net.sourceforge.subsonic.dao.MediaFileDao.getChildrenOf(MediaFileDao.java:86)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:197)
at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:181)
at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:63)
at net.sourceforge.subsonic.service.MusicIndexService.getMusicFolderContent(MusicIndexService.java:73)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:135)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:135)
at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:59)
Caused by: java.sql.SQLException: out of memory
... 64 more
jgraythe4th
Users browsing this forum: No registered users and 114 guests
