No Index in Version 5.3 under Debian for Raspberry Pi 2
Postby BeverlyHeal » Fri Jan 22, 2016 10:16 pm
Hi all,
I have installed the new version of "Subsonic 5.3.deb" on my Raspberry Pi 2.
After search in the media folder all artists, albums and songs will be found.
But in the left side are no table of contents and in the middle no Cover display. :?
The openjdk-7-jre package available!
After downgrade to version "Subsonic 5.2.1deb" everything is perfect.
I thing the OS and the Raspberry Pi 2 will be allright
Have anyone an idea or the same problem?
OS: Raspbian Jessie
Best regard
Beverly
BeverlyHeal
Re: No Index in Version 5.3 under Debian for Raspberry Pi 2
Postby BeverlyHeal » Sat Jan 23, 2016 1:19 pm
Ok! I am waiting for the next version 5.3.1
No doubt... that is a bug, and nobody knows an answer.
I hope subsonic will fix them in time.
The problem describe in more detail? :roll:
Either its going or not. :wink:
BeverlyHeal
Postby mrfloppy » Sat Jan 23, 2016 4:09 pm
Permissions are set correct?
mrfloppy
Postby ethanb » Sat Jan 23, 2016 8:53 pm
Did you ever get this to work? I've tried on first gen RPi with 5.3 and 5.2.1 with similar results. Everything seems to work fine and I'm able to access the web interface and select the location of music but it never shows up as accessible in my library. Right now I have a single song I'm trying to add and on the left hand side I see:
0 artists
0 albums
1 songs
1.6 MB
0 hours
So it knows it's there; just doesn't process it enough to let me play it.
Any ideas?
ethanb
Postby alphawave7 » Sat Jan 23, 2016 10:29 pm
Admin needs user permissions too.
Sent from my Nexus 6 using Tapatalk
Postby BeverlyHeal » Tue Jan 26, 2016 4:22 pm
alphawave7 wrote:Admin needs user permissions too.
Yes! Thank you for this tip "alphawave7" it works!
Menu --> User
Select a user name
and activate --> Allow access to these media Folders
Yeeeh! That was it!
Beverly
BeverlyHeal
