Subsonic 4.5: Server has a weak Diffie-Hellman key
Postby Globe199 » Mon Feb 01, 2016 7:38 pm
Server has a weak Diffie-Hellman key. I got this error a while back since I'm still running Subsonic 4.5. I was able to tweak Seamonkey to get it to work (I only use Seamonkey for Subsonic). But I'd like to use it in Chrome. Unfortunately, Chrome is being a bastage and there's no way around the error.
Can I 'upgrade' the server or certificate in Subsonic 4.5 to fix this error?
Globe199
Re: Subsonic 4.5: Server has a weak Diffie-Hellman key
Postby Globe199 » Mon Feb 01, 2016 7:49 pm
I see some suggestions on adding SSL protocols to a certain XML file in Tomcat, but I'm not seeing any XML files under Subsonic that seem to correspond to that.
Globe199
