Chrome (windows only) issue clicking play
Postby dave31175 » Thu Feb 25, 2016 8:21 pm
In Chrome on Windows 7, when I click play (whether on a track, an album, or a playlist), a download prompt appears to save an m3u file. Any fixes or workarounds? Thanks
dave31175
Re: Chrome (windows only) issue clicking play
Postby dave31175 » Fri Feb 26, 2016 3:12 pm
Is this forum alive? Is there a better place to be posting questions like this?
dave31175
Postby acroyear » Sat Feb 27, 2016 10:37 pm
That's generally caused by having your setup pointing to an "external player".
Resolve it by going to Settings, then Player.
Hover over the player at the bottom so that its own value comes up (in my case, it says "Player 12").
In the settings, select what the player is (I think the value you see is the default, but i'm not sure), and if it is "external" (either with or without playlist), just click to delete it or change it to "Web Player" and save.
Then try to play something.
I hope that works. Haven't needed to do that in a while.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Postby dave31175 » Sun Feb 28, 2016 2:18 pm
Thanks acroyear! I'll give that a try tomorrow when I'm at that computer again.
dave31175
Postby dave31175 » Mon Feb 29, 2016 2:55 pm
acroyear wrote:That's generally caused by having your setup pointing to an "external player".
That worked perfectly! Thanks so much for your help.
dave31175
