How to start Subsonic after install from FreeBSD ports?
Postby nimo » Mon Mar 07, 2016 9:07 pm
I have just installed subsonic 5.3 with jetty from FreeBSD ports collection -- but now I can't figure out how to start it. I have tried strating the provided jetty service. But that just seem to start the jetty service and not Subsonic.
Any advice would be highly appreciated!
nimo
Re: How to start Subsonic after install from FreeBSD ports?
Postby insann » Mon Mar 07, 2016 10:52 pm
Normaly subsonic should be running actually !
if not try to check it with :
service subsonic status
if it isn't running try this :
service subsonic start
Jetty always run after installation, subsonic too !
Check if you have any firewall blocking something !
Router firewall ? Server Firewall ? Running port is 4040 by default !
Check Logs for more info ! ( /var/subsonic/subsonic_sh.log in debian maybe same in freebsd )
( maybe i'm wrong i don't use Freebsd but its almost same as Debian )
Got the info from https://www.freebsd.org/doc/handbook/configtuning-rcd.html
Insann
insann
Users browsing this forum: No registered users and 80 guests
