Nothing Added to Libary
Postby sharktech » Thu Mar 10, 2016 12:55 pm
Hi
I've migrated to an Ubuntu 14 install and everything worked but when I run a scan it see's the music but doesn't show anything under recently added or anywhere, I using 6.0 beta1 build 4676, subsonic is running as root and root has read and write access to the music folder set in subsonic.
log for scan below
[2016-03-10 11:35:33,969] INFO MediaScannerService - Starting to scan media library.
[2016-03-10 11:35:34,233] INFO MediaScannerService - Scanned media library with 250 entries.
------------skipped a few lines :) ---------------------------------------------------------------------------------
[2016-03-10 11:35:41,203] INFO MediaScannerService - Scanned media library with 12894 entries.
[2016-03-10 11:35:41,203] INFO MediaScannerService - Marking non-present files.
[2016-03-10 11:35:41,218] INFO MediaScannerService - Marking non-present artists.
[2016-03-10 11:35:41,218] INFO MediaScannerService - Marking non-present albums.
[2016-03-10 11:35:41,224] INFO MediaScannerService - Completed media library scan.
Thanks in Advance
sharktech
Re: Nothing Added to Libary
Postby alphawave7 » Thu Mar 10, 2016 4:47 pm
Enable permissions for admin in user settings.
Postby sharktech » Thu Mar 10, 2016 8:52 pm
Jesus lol, cant believe that. is it new or linux only?
sharktech
Postby mts7807 » Fri Mar 11, 2016 8:19 pm
Am I understanding this correctly when I read your replies?
The folders need to have the proper privileges? I logged into both my main admin user as well as the user I created with admin privileges to add the media libraries I wanted on my FTP and still no luck, yet my log files read the same as OP.
I'm running Ubuntu linux 15.04 as the OS
The folder I want to share has 755 permission rating and all songs have 644
Not sure if it makes a difference either or not, but the folder all the music is in is just strictly a folder with music files. No sub-directories for artists-names or albums yet.
mts7807
