subsonic not reachable after wake up
Postby TIQA » Mon Mar 14, 2016 2:44 pm
hello.
im running subsonic premium on win10 64bit. thing is that once i set pc to sleep and wake up, subsonic is not reachable from wan, while on lan everything is working fine.
any remedies?
TIQA
Re: subsonic not reachable after wake up
Postby insann » Mon Mar 14, 2016 8:35 pm
We need some more infos to help you out !
Is you're firewall open ? ( on pc and router )
Did you try to restart subsonic ?
i guess its a firewall issue (
first you need a static ip for you're subsonic host , then you need to open the right port on windows and in the box configuration
i don't think its a big issue :p
Insann
insann
Postby TIQA » Thu Mar 17, 2016 5:28 pm
Routing is working fine, because its reachable from outside and no hiccups there. This happens ONLY after puting box to sleep and then waking up.
TIQA
Postby Exrace » Sat Mar 19, 2016 3:47 pm
Is your computer wired or wireless only?
Exrace
Postby TIQA » Sun Mar 20, 2016 12:38 pm
Wired
Edit: everything works fine once i restart subsonic server
TIQA
Postby bushman4 » Mon Mar 21, 2016 2:10 pm
If I had to guess, you did not manually open ports in your router, but are letting Subsonic do it via UPnP.
If that is the case, either manually open the ports on the router, or figure out how to tell your router not to delete the UPnP mapping when the device goes offline (not likely possible).
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
