Pop up errors BETA 6.0 Beta2
Postby edimusrex » Fri Mar 25, 2016 6:15 pm
I just installed a fresh version of subsonic on my server but when I log in the following pops up constantly
Failed to find parameter: instanceId (check server log for more info)
This is running on CentOS 6.7
Help would be appreciated
--- UPDATE ---
I updated java and refreshed my cache which seems to have solved the problem
edimusrex
Re: Pop up errors BETA 6.0 Beta2
Postby fraubi » Fri Mar 25, 2016 8:52 pm
same error here. What is to do ?
Fraubi
fraubi
Postby acroyear » Fri Mar 25, 2016 11:51 pm
a heavy reload of the web page will resolve it. shift control/cmd r, or "ctrl+f5", or if you have chrome, hold the mouse down on the reload button and you'll see "hard reload" and click it.
Basically, there's a caching issue somewhere causing an incompatibility. these hard reloads tell the browser to ignore existing cached files.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
