External player with playlist will not download m3u
Postby bibelen » Fri Apr 01, 2016 8:26 am
Hi.
I'm using Subsonic 6.0.beta2 (build ef60a8) (I've also tried 5.2 stable).
I have tried uninstalling both Java and Subsonic, rebooted the computer for every uninstall and reinstall. I have deleted the c:\subsonic folder before reinstalling and i have cleaned the register with Ccleaner before reinstalling too.
The result is always the same, the m3u will not be downloaded on any of the 3 computers i have tried. What can possibly be the reason for this?
bibelen
Re: External player with playlist will not download m3u
Postby toolman » Sat Apr 02, 2016 12:32 pm
Guess this is an issue in the 6.2 beta-version.
See http://forum.subsonic.org/forum/viewtopic.php?f=4&t=16494#p70714
toolman
Postby bibelen » Sun Apr 03, 2016 9:21 am
I had the same problem with 5.3.
Also, I have noticed that the subonic\subsonic.log file keeps piling up text like this:
/*C1*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C2*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C3*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C4*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C5*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C6*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C7*/SET SCHEMA PUBLIC
bibelen
Users browsing this forum: No registered users and 78 guests
