pre-load music
pre-load music
Postby TheBlackReverand » Wed Apr 06, 2016 3:42 pm
First, sorry for my bad english :?
I use subsonic on my personnal server and internet connection.
When I'm in local network all is good but when I play music by internet I have a loading time for each song.
I use standard web player (integrated with flash).
Transcode is activated but my file are already in mp3.
When I use Subsonic android app it's better, maybe because I have a parameter "pre-load 3 songs".
Do you have equivalent on web player? That can be great :)
Version 6.0.beta2 (build d85b52) – 23 mars 2016
Serveur jetty-6.1.x, java 1.7.0_95, Linux (94,1 MB / 145,0 MB)
No warning in log
Thanks for everything.
TheBlackReverand
Re: pre-load music
Postby toolman » Wed Apr 06, 2016 6:47 pm
Seems like your internetconnection is too slow to stream music. Or to be more precise: the uploadspeed is to slow.
I have a very simple internetconnection with speed of 40 Mb download and 2 Mb upload but still am able to stream
my music from my subsonic-server without stuttering or bufferingproblems.
That doesn't help you very much, but it might be that your problem can be solved by changing some settings in your Modem / router.
Since Subsonic itself doesn't have an option to adjust a buffer size you could consider to adjust the player in your subsonicserver to limit the bitrate to 64 or 128 Kbs.
toolman
Re: pre-load music
Postby TheBlackReverand » Thu Apr 07, 2016 8:47 am
Yes I have a standard connection but it's enough with my mobile in 3G....
The only difference is the pre-load... :?
That can be a good features for web player :D
TheBlackReverand
Re: pre-load music
Postby toolman » Thu Apr 07, 2016 9:33 am
I don't think that you can configure a player to "stream ahead" .
This can only be done at the receiving device.
toolman
Re: pre-load music
Postby TheBlackReverand » Thu Apr 07, 2016 2:12 pm
For your information, I try "PolySonic" add-on for Chrome and I don't have load problems.
I have an option "Precache next track"
TheBlackReverand
Users browsing this forum: No registered users and 79 guests
